Help! What's this inside electrical panel?
GlennDog
GlennDog Posts: 3,121
edited June 2013 in The Clubhouse
I found this inside a household panel board. Are these surge suppressors? There are 2 of them across a 220 breaker
Any help is appreciated . . . Thanks!
G
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
Post edited by GlennDog on
  • zane77
    zane77 Posts: 1,696
    edited June 2013
    Looks like a noise suppressor, a very basic filter
    Two Channel
  • FTGV
    FTGV Posts: 3,649
    edited June 2013
    They are 100nf 250 volt interference suppression caps.The Y2 indicates they are rated for safe useage in the line to ground legs of the AC line without the chance of a failure,thus creating a dead short and potential fire.
  • GlennDog
    edited June 2013
    To be clear, the device(s) are both under a 220 breaker by themselves (not with any other electrical lines/standing alone). Will this "condition" the entire panel? or is it simply low quality attempt to filter noise? If it is not joined with anything, it's useless, right?
    Thanks again!
    G
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • kevhed72
    kevhed72 Posts: 5,073
    edited June 2013
    Noise suppression....as in to eliminate noise in the actual current line (same effect as a power conditioner) , or do they remove any hum coming from the panel itself?
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited June 2013
    Any X10 in the house, maybe a "Cheap Repeater" for it?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    txcoastal1 Posts: 13,339
    edited June 2013
    DJ7 is on the right track. Noise filters have been installed with X-10 and other PLC home automation devices due to communication interference.
    Added if homes had to many "dirty equipment" like fluorescent lighting, pool controls etc
    What breaker appliance is this tied too?
  • GlennDog
    edited June 2013
    txcoastal1 wrote: »
    That's part of my question . . . the 2 of them are installed on the 220 breaker by themselves (no other wires attached)
    Thanks for all of you responses!
    G
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • lanchile
    lanchile Posts: 560
    edited June 2013
    I would take it out! and if you want some kind of filter, I would get a RFI and EMI filter. Cable monster have some. and they work very well. I have one and I have tested it and it really cleans all the garbage that is in the AC line.
    Make it simple...Make it better!
  • disneyjoe7
    edited June 2013
    I may keep it in, if he as X-10 control in the house. Who's complaining?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • CoolJazz
    CoolJazz Posts: 570
    edited June 2013
    With the breaker on, caps would shunt high frequencies.
    At the panel instead of out on the audio circuit leg really should be a good thing for other noise created in the house on other circuits. I can't right off think of any reason to pull them. But adding anything more on the audio circuit would still be good to help with the devices plugged in there, like switch mode supplies.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • disneyjoe7
    edited June 2013
    With the cap on the leg 120vac to the other leg 120vac it would put the high frequency to the other leg if the noise is one of the leg. This cap is bridging signal to the other leg when the signal is on one of those legs. If a cap was wired to a leg and a neutral then yes this cap is shunting high frequencies.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
