Major stupid speaker set up..
naturallight
naturallight Posts: 689
edited June 2013 in 2 Channel Audio
Now this is really stupid, the setup you see, the 12's would not be there...I just took the pic, as it sits right now. The 1C's and the Advents are working. the only ones that are working. Now why i bothered to do this not sure..the CD i was playing was Creed. Now the 1C's alone will beat you with that CD.
BUT..if you stick the Advents on top..then it becomes beyound stupid. I did not disconnect the SDA cable..BUT at least with this CD..didn't seem to make a difference..stuff was flying around the room..not that it's a great SDA type cd to begin with.
I have no words for this..you can't turn this past 10 1/2 on the volume..you would just beat yourself to death or go deaf. I tend to think the overall sound is not that great..but i will have to walk away from this mess..listen another day with a better cd. I don't see how this can really work that well at all. But if you want bass..man this will give it to you...LOL
Post edited by naturallight on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited June 2013
    Stupid is as stupid does...
  • heartystatue
    heartystatue Posts: 329
    edited June 2013
    There are no words
    HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
    2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC.
  • Poolgod69
    Poolgod69 Posts: 184
    edited June 2013
    :eek:
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
    Elemental Designs A2-300 Subwoofer
    Panamax M4300-PM Power Conditioner
    Working on updating my set up :rolleyes:
  • wayne3burk
    wayne3burk Posts: 939
    edited June 2013
    ...Out here on the perimeter there are no stars
    Out here we is stoned immaculate...
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
  • halo71
    halo71 Posts: 4,632
    edited June 2013
    --Gary--
  • boston1450
    boston1450 Posts: 7,758
    edited June 2013
    ....lol....
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Malbec
    Malbec Posts: 558
    edited June 2013
    wayne3burk wrote: »
    Channeling the Lizard King.
  • Irrenhaus
    Irrenhaus Posts: 1,102
    edited June 2013
    Malbec wrote: »
    Hey good screen name nice wine....
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • Dawgfish
    Dawgfish Posts: 2,554
    edited June 2013
    halo71 wrote: »
    Which one? Me too btw! Got to love Friday night.
    gudnoyez Posts: 8,161
    edited June 2013
    Why not take the 12's and the Advents out of the mix and then experience the difference it makes. Kudos to Friday nights!
  • naturallight
    edited June 2013
    LOL..i only did this because somebody had said something about stacking speakers..it is just a test and joke. I had the extra speakers sitting there, so i tried it.
    The 12's are NOT hooked up, they just were sitting there when i took the pic. Surprisingly it does not seem to DESTROY the SDA "effect", what it does do, is seem to make a "wall" of sound..it is massive and you hear stuff from the top to bottom of your room..plus massive bass.
    Not that this is great, or anything else. With the old Advents on top of the SDA's..it does seem to work to some degree. I'm not saying it sounds great..but does kick your ****..big time. It was fun to try out. But i'm sure when i go back downstairs with a "sober" pair of ears, it's not going to sound too good...LOL
  • Bob in WI
    Bob in WI Posts: 155
    edited June 2013
    cool in a stacked wooden boxes sort of way.
  • BlueFox
    BlueFox Posts: 15,251
    edited June 2013
    Nice speaker stands. Try to get the wall color to coordinate with the speakers for a synergistic coupling.
    Toolfan66 Posts: 18,064
    edited June 2013
    Mystery's set up is worse, and he continues to tell us what sounds better..:rolleyes:
    Sorry Mystery, but it is, and has been a mess..
  • naturallight
    edited June 2013
    Normally there is only 1 set of speakers sitting there. Either the 12's or the SDA's. Which ever set is not in use is moved completely out of the way on a side wall. The 12's are a real pain to move. So for this silly test, i did not bother. Just moved them over some, and slid the SDA's in between.
    Now if you play just rock, which for the most part has no real SDA "effect" going on..it did not sound too bad. BUT after X amount of drinks..anything probably sounds OK.
    Once i go back down stairs and try this again..more then likely it will sound bad. Then i can just put everything back to normal and say, well that was fun. If for some reason, it may not sound like crap.
    I might move the 12's out of the picture, set the SDA's right, in there normal space. Flip the Advents, so the tweeters are all in line, and the bass driver being on top. Then put on something i know has a good SDA "effect" on it and see what happens. Now i don't expect this to work too well, It has to mess with the SDA "effect". But since i went this far, might as well set it up the SDA's the way it should be and see what it really sounds like. If i pull the SDA interconnect cable, so the 1C's play like normal speakers. Then this probably works and you have just a massive speaker set up beating you to death....LOL But little point in that if you like the SDA "effect"
  • breystonfan
    breystonfan Posts: 15
    edited June 2013
  • zingo
    zingo Posts: 11,258
    edited June 2013
    I bet the Creed sounds worse than any of the multiple speakers configurations will...
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited June 2013
    I think these are the guys who really got that wall right for a year or so
    http://dozin.com/wallofsound/index.html
  • leftwinger57
    edited June 2013
  • naturallight
    edited June 2013
    Ok..stacking Advents on top of SDA 1C's....really doesn't work that well.....Like Duh..
    It does not completely kill the SDA "effect" but it's not great. If you wanted to turn your basement into a disco..then it will work, does give you a "wall" of sound. But otherwise..not so great.
    The Advent is not something you want to stack on a SDA 1C...to make this work at all, you would need a separate power amp to run the Advent that you could control the volume. So you could at least match the volume out of both the 1C's and the Advents.
    The only thing that may work if you really wanted to stack speakers..or at least SDA stuff.
    If you got a set of CRS..put that on top of a set of 1C's..with a separate amp that can control the volume. MAYBE..MAYBE that would work. You may end up with a poor mans SRS 1.2....LOL
