Just got a pair of Monitor 5's!
AFEuphman
Well, I finally have the time to dig into the old CRS+'s and needed something to listen to in the down time. I got a good deal on a pair of Monitor 5(B, I think) and a pair of BA A40 Ser II's that need refoamed all for $95. Not bad!
So, the information on the CRS's is extensive, and I'll be using the heck out of it, but I could use some help on the basics of the monitors. I'm having trouble finding info on hight, distance to listening position/apart, etc...
Seems the Monitors are meant to be angled back about 6 degrees... Is that the same for all the models? I assume my 5's will have to be higher... Does that change the angle?
Anyway! Too many questions! Thanks for any and all help! I'm so excited!
