Bulk In Wall Speaker Wire
daboyz
daboyz Posts: 5,207
edited June 2013 in Wanted (WTB) Classifieds
My brother just bought a new house and is looking for appx. 500 to 600 feet of wire to run through the house. 12 AWG is preferred. We've already priced Blue Jeans and Monoprice.
Thanks!
Post edited by daboyz on
  • Speedskater
    Speedskater Posts: 495
    edited June 2013
    The best kept secret for in-wall speaker wire is 14/3 plus Ground Romex®(NM). You connect tie Black & Red together and the White & Ground together, then you have an 11AWG speaker wire that's twisted and rated for in-wall use.
  • David R
    David R Posts: 134
    edited June 2013
    I got some from Monoprice which worked well.
    Panasonic 65" Plasma - Panasonic Blu-ray. Onkyo TX-NR809 RTi A7s fronts - MK CS150s surronds.
  • daboyz
    daboyz Posts: 5,207
    edited June 2013
    I've got 12 speakers to run.
  • DaveHo
    DaveHo Posts: 3,583
    edited June 2013
    Monoprice is your best bet if you want to keep the cost down. I've used the Monoprice before & 12/2 CL3 rated wire from JSC Wire & Cable. The JSC has a tougher outer jacket & better fill material so that the wire is actually round & not sort of round like the Monoprice stuff. Plus the JSC is made in the USA, pretty sure the Monoprice is not. That said, I see no reason not to go with the Monoprice 12/2. I'm using both in a distributed audio system & hear no difference in that application.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited June 2013
    BlueJean speaker cable is Belden speaker cable and if I was building a house that's what I would use hands down.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
