Another HVAC question
madmax
My HVAC system is in the basement and whenever the AC or heat comes on it pulls my basement door on the main level closed. Why does it do that and is this a problem?
madmax
madmax
Vinyl, the final frontier...
Post edited by madmax on
It means your system is 'out of balance', meaning, you have more supply, than return. The only way to fix it is by adding the CORRECT size ductwork.
If it's more than 1 story, you'd have to run a return plenum from the 1st/2nd/3rd flr. down to the basement.
Basically, a chaseway, common to all floors.I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
+1 with obieone. Whats happening is your over pressurizing the area/room where doors close. Easiest fix is to add return air in those rooms. Will not be cheap, but usually 1 square foot of return air in any room experiencing this will work. Sometimes a little more is required. Call a company that has a good reputation, and not the cheapest one. They will usually evaluate a situation like this at no charge.
Also make sure all your air vent(registers) in other rooms are open, no leaks in any plenum or ducts, and you don't have any closed doors on any of the other rooms?
Thanks for the input! I do have a bunch of closed doors, will first try opening all of them.Vinyl, the final frontier...
Have you changed the return air filter lately??Polk SDA 1.2 TL
Infinity SSW-210
Integra DTR 7.1
Pioneer SC-57 Elite
Sony X777ES
Sansui BA-5000
Hafler XL 600's in mono w/ George Kay Audio Tube upgrades
Hafler xl 600 stock
Krell FPB 600
Avel 1000VA Dreadnought -
madmax
When mine did that it was all from unsealed return duct joints, hard to believe they leak that much.
