Opinion on speaker hook-up?
jpurcell
I recently purchased a polk 650 sub with a 7600 speaker system. In the speaker manual they recommend hooking the fronts up to the sub and not using the low freq out from the receiver. Thats the way I hooked it up. Does anybody have an opinion on
hooking up the fronts to the receiver and using the low freq from the receiver. I have a onkyo 797 receiver if that makes any difference.
Jim
Jim
Post edited by jpurcell on
you'll find that both of these wiring methods are acceptable, and both will work. which one is better- that is up to you to decide. many prefer the way that you have it wired now, reciever-to sub-to fronts. it allows for the most 'customization' of your bass management. wired this way, remember to set your reciever to sub-'off/no', and fronts-'large'. you can try hooking up the LFE and see if you like it, but the main benifit of that is ease of hook-up. many recievers (i do not know on yours, but your manual would tell you) have the LFE out prefiltered, which does not allow you to 'tweak' your sub's roll-off frequency to the front's, it's just a designated frequency that it is cut-off at. i hope this helps...
I have an older model KENWOOD reciever that is dolby prologic. If I cant change my sub to OFF and fronts to LARGE what do I do? I have MODEL PSW350 sub with RM6200 Polk Audio theatre system(small fronts and rears)
METALLICA ROCKS!!!!!!!!!!!!!Originally posted by NFL36
I have an older model KENWOOD reciever that is dolby prologic. If I cant change my sub to OFF and fronts to LARGE what do I do? I have MODEL PSW350 sub with RM6200 Polk Audio theatre system(small fronts and rears) -
run speaker cables from your receiver front R/L outs to the sub's R/L input's, then from the sub's R/L outputs to your R/L front speakers respectively...
