t- nuts (does size matter?)
soundfreak1
soundfreak1 Posts: 3,414
edited June 2013 in Vintage Speakers
8-32.......1/4x 20 ?????? doing a pair of RTA12C's, any size better than another???
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
  • canadianicon25
    canadianicon25 Posts: 200
    edited June 2013
    i would say go with the smallest you can. ideally #8 assuming the holes in the cabinets haven't been drilled out larger than the hole size used for a #8 tee nut.
    i don't think thread count matters.
    i used #10-24 tee nuts because my monitor 5's had holes drilled larger for plastic inserts that were in there already so i couldn't use a #8 tee nut. i think #10 cap screws look too large, especially for the tweeter.
    if possible use hurricane nuts from parts-express. tee-nuts are hard to install especially in MDF or particle board.
    F1nut Posts: 50,753
    edited June 2013
    Do NOT use T-nuts for anything other than mounting spikes to the base of a speaker cabinet.
    You want Hurricane nuts and the thread size should be 8-32.
  • zane77
    zane77 Posts: 1,696
    edited June 2013
    +1 on what Fi said
    Two Channel
  • soundfreak1
    edited June 2013
    Thanks f1, Zane.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
