Music Hall 5.1SE turntable
Gman52
Gman52 Posts: 4
edited June 2013 in Electronics
I just ordered a Music Hall 5.1SE turntable and I was wondering if anyone has or had this turntable and could give me some feed back on how this sounds. It was sold out and I have to wait 2 weeks for it to come in.
Post edited by Gman52 on
  • Bob in WI
    Bob in WI Posts: 155
    edited June 2013
    Don't have one but the fact that its popular is surely a good sign.
  • Msabot1
    Msabot1 Posts: 2,098
    edited June 2013
    For the price it is hard to beat this piece of equipment! This table will handle your vinyl nicely! Good choice!
  • Bob1947
    Bob1947 Posts: 39
    edited June 2013
    I am also considering a Music Hall 5.1 SE with a Mojo cartridge for about 1095 at Audio Advisor. Also looking at a Rega RP3 with a Elys 2 cartridge. Both have a tone arm clamp, dust cover and include a rca cable (would upgrade this). Both are priced at 1095 with cartridge. It has been years since I owned a tt and really have little (retainable) knowledge of what makes one better that the other. Anyone know what some of the key features would be that make either one better than the other? Both get good reviews, both look very good as far as quality is concerned. Any comments, appreciated.
    Regards, Bob
    Samsung PN51E6500 Plasma
    Marantz UD 7006 7.1 Blue Ray/CD/DVD Player
    Marantz SR 7007 HT Procesor
    Polk LSiM 705 Fronts
    Polk LSiM 706c Center
    Polk LSiM 703 Rear
    Klipsch RW12D Sub
    Music Hall 5.1 SE TT
  • cstmar01
    cstmar01 Posts: 4,424
    edited June 2013
    I have the MH 2.2LE and while it is a nice table the 5.1SE is better and I wish I would have started more at that point then the 2.2.
    The other table around that price point that I really like is the VPI Traveler. Very impressed with that table so far from the listening I got at the dealer I heard the table at. It is above the price of the 5.1SE however I do like the table better overall.
  • Bob1947
    Bob1947 Posts: 39
    edited June 2013
    I'll check out the VPI. I am leaning toward the MH 5.1. That price with a MOJO cartridge is hard to beat. Have only seen that price on Audio Advisor so it bears more shopping around to see if their's is the best I can do. Thanks for your comment.
    Regards, Bob
    Polk LSiM 703 Rear
    Klipsch RW12D Sub
