Cap Upgrade Ideas for VTL's
cstmar01
cstmar01 Posts: 4,424
edited June 2013 in 2 Channel Audio
So, when I got my amps the guy I bought them from stated they have upgraded MIT caps. However after looking at them not 100% sure they are as some are not marked so was thinking about recapping the amps at some point.
I heard that some guys did paper and oil caps and was looking to get ideas.
I don't want to add anything sluggish to the sound and still want it to remain open and clean. I like the sound of the amps but just want to ensure they will last awhile still.
Post edited by cstmar01 on
  • lanchile
    lanchile Posts: 560
    edited May 2013
    Are you recapping the power supply of your amp?
    Make it simple...Make it better!
  • thsmith
    thsmith Posts: 6,082
    edited May 2013
    Send email to VH Audio @ vhaudio.com. Chris is great.
  • zingo
    zingo Posts: 11,258
    edited May 2013
    thsmith wrote: »
    Great suggestion
    F1nut Posts: 50,734
    edited May 2013
    Mundorf.
  • headrott
    headrott Posts: 5,496
    edited May 2013
    +1 on Mundorf. I use the Silver in oil in my DAC and they are fantastic! The silver and gold in oil I hear are even better, but have not personally heard them. The silver in oil are worth the price though, I will say that.
  • W WALDECKER
    W WALDECKER Posts: 900
    edited June 2013
    Dueland Alexander copper foil in oil are supposed to be great capacitors.
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
