PNF Audio Symphony 10 ft. speaker cables with Kimber Postmaster spades.
headrott
I have a pair of PNF Audio Symphony 10 foot speaker cables that are covered with the black and purple sleeving and purple and black shrink tubing. They are terminated with Kimber Postmaster Ultraplate plated spades (these are the PM33, bigger sized spades) on both ends. I bought these brand new from PNF Audio about 3.5 years ago. They are in excellent condition all around. I have to many speaker cables and do not need these anymore. I believe I paid $220.00 plus shipping for these cables if I remember correctly and will sell these for $70.00 plus $18.95 "Flat Rate" Priority Mail shipping and insured to CONUS. Pictures are below.
Post edited by headrott on
pm sent
If WagnerRC passes I would like a crack..
Headrott, you got yourself one heck of a salesman, lol
DSkip you working in commission? LolATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables -
Continous Casting Copper & Teflon Dielectric = http://www.stereotimes.com/cables051104.shtml
Sounds like these cables are using a CC proccess that I have been touting for years. The car audio company MTX used to make a VERY nice IC years ago...that was home audio quality IMO in their Expert series. I purchased several of these and I've found them to sound great. When, I decide to spring a little coin on cables for the home I will be looking for cables with the CCC proccess...its just a process that that makes sense to me....given all of the claims that are out there about cables. These PNF sound like cables I would buy.
ThunderLink Expert - (I use these for high and midrange)
With a very high-gloss, elegant look, the Expert is the best cable choice if you want absolute lowest noise possible. The connectors are machined on a CNC lathe, chromed, and then plated with 24-karat gold.
Skin Effect = High Fidelity
This cross-section diagram of a single strand of wire shows the Expert’s silver coating. Silver is a superior conductor. We use it as the coating, because the higher frequencies travel close to the surface of the cable (this is a phenomenon called “skin effect”). This makes the Expert Interconnects the best choice where the maximum degree of high fidelity is expected.
• “Twisted Twins” (twisted, twisted pair RCA cable)
• 7 mm of black pvc, with a clear overlay jacketing
• Chrome and gold-plated ergonomically designed RCA plugs
• 24-karat gold-plated split center pin (for a better connection)
• 24-karat goldplated six-segment outer conductor rings (for the tightest fit)
• Dual strain relief (machined end with polyethylene innermold)
• Teflon dielectric
• Silver-coated, OFC copper stranding
________________________________________
ThunderLink Competition - (I use these for midbass and sub)
In the Competition, we take two pairs of twisted pair wire and twist them together. This further reduces the loop area, where extraneous noise is introduced. Our engineers (who are pretty twisted themselves) call this “Twisted Twins.”
Traditional copper casting yields many small crystals. The dark spots are the impurities. (Nasty, huh?)
The OCC (Ohno Continuous Casting) process results in fewer, larger crystals with very smooth surfaces and way less impurities.
OCC Copper: Higher Purity = Better Signal
The superior level of purity from the OCC process means less resistance, higher conductivity and a better signal.
OCC Copper Provides Better Bass Response Low frequencies pass through the conductor toward the center, where there’s a high concentration of very pure, OCC copper. This makes Competition the logical choice for enhanced bass response.
• “Twisted Twins” (twisted, twisted pair) RCA cable
• 7 mm of pearl red, extruded PVC jacketing
• Pearl red, ergonomically designed RCA plugs
• 24-karat Gold-Plated split center pin (for a better connection)
• 24-karat four-segment outer conductor rings (for tighter fit)
• Double-molded strain relief (inner polyethylene with pvc overmold)
• X-tra Long Junction Block to Connector
• OCC Copper Stranding2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
paypal sent. Thank you
Please mark these as sold. Thank you Bob very much.
I have these for my speakers and the icons for my interconnects. You will love them and at that price there is no way you can go wrong. Congrats on fine speaker cables!HT System
Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ. -
Somebody just scored some killer speaker cables at a ridiculous price. I still have a pair of these that I'm keeping. I think their Iconn IC's are great sounding too. I use them for my HT applications.
