Need cable/stereo rack suggestions.
c_corie
c_corie Posts: 138
edited June 2013 in 2 Channel Audio
Currently in decent sized living room with a high slanted ceiling- speakers are probably 10 feet apart or so.
Speakers: B&w CM8s
Amp: Marantz PM6004 (Just got it- after much debate)
DAC: Hegel HD2
CDP: Older Rotel model DVD player...don't know if I'm going to keep it setup so I don't NEED space for it in my rack/table.
Interconnects: Have decent ones ($40 for 3? feet) forgot the brand- they are in my trunk- currently using Radio Shack ones...
Speaker Cable: Just crappy best buy, or radio shack stuff...I really need decent looking/sounding cables and no more of this bare wire crap- might be into bi-wiring.
So I need suggestions for speaker cables, and a rack of some sort to put this stuff on...right now it's sitting on an Ikea lack table, it looks cheap.
Post edited by c_corie on
  • ZLTFUL
    ZLTFUL Posts: 5,655
    edited May 2013
    A budget would help as there are some very nice options out there but also some very expensive ones.
    Same goes for both the speaker cable and the stand/rack.
  • c_corie
    c_corie Posts: 138
    edited May 2013
    As cheap as possible, but still a good match with what I've already spent. Cables lets say under $150 stand under $110- I don't care if it's small I just need two shelves and a decent look, also needs to be wide enough to hold the Marantz.
  • mrbiron
    mrbiron Posts: 5,711
    edited May 2013
    Look up VTI Audio Racks. Cheap yet quite nice.
  • steveinaz
    steveinaz Posts: 19,538
    edited May 2013
    Believe it or not, Walmart has some pretty nice looking/inexpensive equipment racks lately. Might want to check them out.
  • Glen B
    Glen B Posts: 269
    edited May 2013
    c_corie wrote: »
    A decent stand under $110.00 is a challenge. I've learned the lesson over the years that its better to spend a little more on quality from the start versus buying too cheap then needing to upgrade too soon after. If you can increase your budget somewhat, the Sanus Euro 3-shelf unit is $199.97, and Salamander Archetype 3-shelf flexy rack is $169.00, both in black finish. Both are good, sturdy units, and the prices are about right for the quality. I have not seen anything cheaper that is as good, although there could be something somehere that I missed. The middle shelf height of the Archetype is infinitely adjustable, and so can accommodate any height equipment as you change components.
    Sanus Euro rack
    Salamander Archetype flexy rack
  • Glen B
    Glen B Posts: 269
    edited May 2013
    The Sanus AFA 4-shelf rack is available at One Call and several other places for $149.00.
    Sanus AFA 4 @ One Call
