LSi Sub Mod...Going In...
hochpt21
hochpt21 Posts: 5,423
edited May 2013 in Speakers
A lot of people say this mod is super duper simple. This will basically be my first...so I hope so. Anyway, I have studied the mod thread and am planning to dynomat the outside of the port tube as well as the spokes of the new db driver.
While I have them open...is there anything else I should/could do? Should I dynomat the other drivers? If so how do I access them?
Any input/advice is appreciated.
Thanks,
Paul
Post edited by hochpt21 on
  • hochpt21
    edited May 2013
    Bump...I am prepping for surgery.
    Anything I should or could do to the 15's while I am in there?
  • ZLTFUL
    ZLTFUL Posts: 5,655
    edited May 2013
    Sounds like you have the important ones down except for going neck deep on crossover mods...but that is a whole other can of worms.
    The sub swap, port and dynamat on the sub basket should do nicely to clean up the bottom end for you.
  • Jer.War
    Jer.War Posts: 180
    edited May 2013
    Its all pretty tidy in there as I remember.... You will need something to make a gasket for the new db woofer as it wont fit unless you remove the rubber surround. :)
    [The Ever-Evolving System
    LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD.
  • hochpt21
    edited May 2013
    Thanks ZLTFUL and Jer.War.
    I've got some armacell for the gasket.
    Looking forward to the results.
