Crossover for LSiM705
airlung
airlung Posts: 24
edited May 2013 in Speakers
In theory, what crossover should I be setting for my LSiM705? Full Band or ny other Frequencies. I am using a Sunfire HRS 12 woofer, thx
Post edited by airlung on
  • pearsall001
    pearsall001 Posts: 5,200
    edited May 2013
    airlung wrote: »
    Here's a great article that touches on the subject. When I had my LSi15's the 80xo point worked best. And now with my KEF Q900's the 80xo is still the nicest sounding to me. And trust me I played around with every conceivable scenerio. I think there's a good reason the pros recommend the 80xo point. Of course nothing is set in stone so play around till you find what works best for your system. http://www.ecoustics.com/articles/set-speakers-small-receiver-setup/
  • blehmbo
    blehmbo Posts: 179
    edited May 2013
    Try out different settings and see which one sounds the best to you. Using your own ears with your own gear is usually the best way.
  • airlung
    airlung Posts: 24
    edited May 2013
    yes, tried both settings and 80xo seems better! Thanks for the advice! both of u
