speaker damage
2-tall
i have 3.1tls just found some old infinity speakers in a relatives basement.The foam around the wolfers have cracks. Is there any way to repair these beside buying replacement speakers?Thanks 2-tall
Post edited by 2-tall on
You need to look for surround replacements with the model number of the speakers you want to fix. Many people offer them. They are just the surrounds and what you do is remove the old foam, place glue around the edge of the cone, place some spacers around the mag to hold the VC in place and glue on the new foam surrounds. Anyone can do it but it takes a little patience. If you cant find the replacement surrounds I will give it a look for you.
