Need advice for getting into vinyl ..... totally clueless!!!
polkfarmboy
polkfarmboy Posts: 5,703
edited June 2013 in Electronics
There is an abundance of vinyl out there more than there is for high res downloads so it has me thinking about jumping in the deep end. I do not wish to start off with something too expensive and want to keep the budget low. What do I need for this and what takes priority in the chain?
I know nothing about phono preamps as its all alien to me and cartridges are crazy expensive so I want a mid range one and a mid range phono pre.
IF I figured $1800 max for a turntable, $500 max for a cartridge would I get decent sound? I dont have a clue about the phono pre but would hookit up to me Anthem D2 for starters
I am not going to rush out tomorrow and buy all this but am quite eager to hear a nice analog track
Post edited by polkfarmboy on
  • nspindel
    nspindel Posts: 5,343
    edited May 2013
    It'll be a shame when you break that $1800 turntable!
    txcoastal1 Posts: 13,519
    edited May 2013
    Since your not in a big hurry, go used on the TT and pre and new on the cartridge.
    On the TT it's a little more risky but maybe a dealer demo.
    Select the TT first.
  • polkfarmboy
    edited May 2013
    Whats the ball park figure for the phone pre and what options are there
  • Obsession18
    Obsession18 Posts: 191
    edited May 2013
    From your post it looks like your willing to spend about $2300 total, this WILL get you a nice rig including table, cartridge, phono-pre and cables.
    This is the rig I put together within you're price range:
    Table: VPI Traveler about $1200 -$1300 without cart, easy to set up and built like a tank.
    Cartridge: Ortofon 2M blue - $225, you really don't have to spend more then this to get great sound.
    Phono-Pre: Project Tube Box DS - $700, very dynamic engaging sound, $500 to $1000 will get you a nice pre (look for one with dual mono design).
    Cables: SignalCable Silver Resolution tonearm interconnects from table to phono-pre and Analog 2's to pre-amp -about $150.
    Don't forget to add record cleaning supplies to your budget, right now I'm using the sink cleaning method but am considering the vacuum path, this can up your budget quickly!
    Once you get it all dialled in you may never want to listen to anything digital again.
    2-Channel System
    Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
    CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
    Spkrs: Tyler Acoustics Linbrook Signature Systems
  • Dawgfish
    Dawgfish Posts: 2,554
    edited May 2013
    You have A LOT of options within your budget! The VPI Traveler mentioned above is a good option. Personally in your price range I would look for a used VPI Scout. They appear all the time on the Gon in your price range. The Clearaudio Concept is another great table. To be honest there are a plethera of good tables that can be had in your price range new or used. Since you have some time, get your read on and look into all of the options you have out there because there a lot.
    Some good phono pres in your price range include Jolida JD-9s, ProJect Tube Box IIs, and PS Audio GPCH. Each of these are good sounding pres that offer a lot of adjustments allowing you to try a wide range of cartidges, becuase believe me once you get into vinyl, you will try a lot of different cartridges!
    Some good cartidges in your price range include Grado Reference Platinum or Sonata (high vs low output), Dynevector 10X5, Denon 103R or 301, Ortofon MM Bronze, Clearaudio Performer V2 Ebony, etc., etc. If you go the used route on a cartridge you have literally 100s of options in your price range. Cartridges can sound very different from each other, so again get your read on to get a feel for what cartridges may have the sound your are looking for. It may take actually trying a few before you find what you like. My current favorite is the Grado Reference Statement, but there are many others that I have enjoyed. The Grado sound is polarizing to many, they either love it or hate it. I love it!
    BTW, as the others have suggested, I would include room in your budget for a good record cleaning machine. I would just buy a used VPI 16.5 or similiar and be done with it. You can have the finest vinyl setup on the planet, but if your records are dirty it won't sound worth a damn. I would consider this a necesary component just like the table, cart, and phono pre. Buying a RCM is the best thing I've done regarding my enjoyment of vinyl. I couldn't see doing without one now.
  • hochpt21
    hochpt21 Posts: 5,423
    edited May 2013
    Dawgfish wrote: »
    The GCPH is very good in my system.
    I agree. The Grado gold is my current and favorite to date.
    Absolutely correct. The best purchase I have made.
  • Dawgfish
    edited May 2013
    Thanks Hochpt21!
    nooshinjohn Posts: 26,105
    edited May 2013
    Look for a vintage table first. Vinyl is NOT for everyone and you may find you just don't like futzing with it. if you find getting up every 15 minutes to flip a record, 20 minutes worth of cleaning a record, then cleaning the stylus before you can even play them worth the investment, then go big at that point...
    Cartridges and styli are by far the most delicate pieces of gear in my rig, and as careful as I am with them, they can attract damage like a magnet.
    I love vinyl personally and it is my medium of choice for serious listening, but for everyday listening, it's digital. Somehow I think vinyl will prove itself to bothersome for you with time. You can get a very good vintage table/new cartridge for less that 500 bucks and put the rest towards buying a few records to see if you like it first.
  • Obsession18
    edited May 2013
    Some tips on cleaning records, once you have determined the method that you will use - DO NOT USE the old inner sleeves, buy some new poly lined inner sleeves. The old sleeves will just muck the record back up, I tried using a hair dryer to blow the old sleeves clean - trust me not the way to go. Once your records are clean all they will need before each play is to run a dry brush over them, you shouldn't to have clean them again for quite a while.
    As for stylus cleaning - Magic Eraser cleaning pads are your friend, Google will tell you how to do it.
    2-Channel System
    gudnoyez Posts: 8,204
    edited May 2013
    Yep get your toes wet first PFB, get a decent used table with a decent cartridge a few lp's before you go all out you never know the vinyl ritual may not be to your liking.
  • PSOVLSK
    PSOVLSK Posts: 5,433
    edited May 2013
    gudnoyez wrote: »
    Another vote for going this route. While I have a modest vinyl system, I'll admit it's not really for me. Love the sound, but not the effort required.
    edited May 2013
    PSOVLSK wrote: »
    Bingo, my thoughts exactly. Vinyl can sound great but the effort and cost and inconvenience is overwhelming. My advice is to put that coin into a digital rig and don't look back.
  • Obsession18
    edited May 2013
    Vinyl may not be convenient but it sure is worth the effort. Before I acquired my current rig, I gave vinyl a test run by breaking out an old crappy Akai TT paired with an ART DJ Pre-II (phono pre - $49) and a generic $15 replacement stylus for an AT cartridge. Spent about $25 bucks on some "in-the-sink" cleaning supplies and $5 for a used copy of Steely Dans Aja.
    I was pleasantly surprised at the sound quality and shocked that is was slightly bettering my Jolida CD player on the same album, how could this be, back in the late 80's I was convinced CD's ruled.
    My current rig wipes the floor with my CD player; wider deeper soundstage, everything just sounds more 3 dimensional and full and the dynamics are just crazy.
    2-Channel System
  • madmax
    madmax Posts: 12,434
    edited May 2013
    I'd go with used equipment. There are a lot of synergy issues between tables/carts/preamps and it can be a few iterations before you get to where you want to be. Its nice to try what you want and be able to trade it back into the market without loosing cash on each try. It makes the decision making less stressful and keeps the whole process from becoming a money pit. :)
    Vinyl, the final frontier...
  • nspindel
    edited May 2013
    tonyb wrote: »
    I don't know if I'd go that far. "Overwhelming" is a pretty strong word. Yup, there is effort and cost involved. But it's an investment of your time and money, that if done correctly will pay dividends for a long time.
    I agree with the advice about going used. This way you can get your feet wet before you dive off the high board into the deep water.
    I started with a used Thorens TD-166 MKII with a Shure MX97e. Not a bank breaker at all. I bought a few records and piggy backed an old receiver to be my phono pre. And I loved the sound!
    Next investment, before I even bought a higher end turntable/cartridge, was my VPI 16.5 record cleaning machine. If you don't own an RCM, I can see little reason to upgrade to a good table and cartridge. You'll never enjoy the blissful vinyl sound if your records aren't kept very clean. Cleaning the records is where the majority of your time is invested. I clean every record with distilled steam, then vacuum, then MoFi deep cleaner, then vacuum, then MoFi record wash, then vacuum. It's definitely an investment of time - 10 records takes me about 1.5 hours. But then they're done, and if you take care of them, you shouldn't need to repeat that for a long, long time. All that's needed after that is a quick dry-brushing before playing the album. And the earlier advice to keep your records out of the paper sleeves is spot on. I place every record in a MoFi anti-static sleeve.
    I also use the MoFi stylus cleaner to keep the needle spotless.
    Once I determined (and it didn't take long....) that I was all in with the vinyl, I sold the Thorens and bought a VPI Traveler and a Grado Sonata cartridge. I also purchased a Dared MC-7P preamp with a phono stage, which I recapped. Now I have over 300 records, all are clean, and I am enjoying them tremendously.
    If you're willing to make the investment, it pays off nicely.
  • polkfarmboy
    edited May 2013
    I was looking at vinyl cleaning machines and they were around $500 and I think thats like getting kicked in the stones once your already down after handing over lots of cash.
    What is 'operation as a moving magnet system' and is it the best sounding ? Also when a turntable says 'stylus included' does that mean you do not need to buy a need or what ever its called
    edited May 2013
    You have much to learn, young Skywalker...
    At this time in your vinyl journey, might I suggest one of these to get you stared...
    treitz3 Posts: 20,276
    edited May 2013
    You can say that again. Oh, yeah!
    edited May 2013
    You must not be old enough to have participated in the old enough to remember when thread, if you have no previous experience with a turntable. A cartridge consists of a stylus (needle). Just start with a used TT with a good cartridge and go from there.
  • nspindel
    edited May 2013
  • polkfarmboy
    edited May 2013
    I have to get something that has WAF and WFA 'wifes friend's appeal'
    I still don't know the answers to the questions I asked about a turntable saying its best as 'operated as a moving magnet system' and that it has 'stylus included' in the same description.
    I was thinking something like this and its alsowhere my questions originate from if you read the description http://www.ebay.com/itm/260945809463?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
    edited May 2013
    That is way too much table for just getting into vinyl IMHO.
    You will become so frustrated with tweeking it and trying to find the right cartridge setup that you wont enjoy the experience. Seriously dude, I know we have not been biker buds around here, but on this I am trying to help. The best way to go is to keep it simple and start slowly. get some experience with a budget table first like this...
    http://www.ebay.com/itm/Yamaha-YP-800-Manual-Turntable-with-new-Stanton-stylus-/251279616153?pt=Vintage_Electronics_R2&hash=item3a816ea899
    http://www.ebay.com/itm/REVOX-B790-DIRECT-DRIVE-TURNTABLE-/230981869853?pt=Vintage_Electronics_R2&hash=item35c797a11d
    http://www.ebay.com/itm/Gorgeous-MARANTZ-6300-Servo-Direct-Drive-Turntable-Record-Player-w-Auto-Off-/151052543070?pt=Vintage_Electronics_R2&hash=item232b6ee45e
    These tables are all excellent performers that will allow you to get your feet wet, then sell and move on later without loosing a dime. You can get your learn on and see if vinyl is for you. If not sell it and move on without taking a bath on new gear you won't keep anyway...
  • nspindel
    edited May 2013
    Maybe one day, when you're good and ready. But that's way too high of a budget Keep it simple to start.
    There are two types of cartridges, moving magnet and moving cartridge. Moving cartridge can have better sound quality, but it puts out 1/10th the power of moving magnet, so you need a phono preamp that can handle moving cartridge. Personally, I use a moving magnet cartridge.
    The stylus is the actual needle itself. The stylus rides in the grooves of the vinyl, and vibrates. That vibration passes through the cartridge and out the tonearm wiring into your phono preamp.
  • Obsession18
    edited May 2013
    You don't need to spend $500 to get clean records, I spent about $25 to set myself up with the method outlined in the link below, instead of the fancy label saver shown in the link I used a pair of small dent pullers I got at Harbor Freight.
    http://www.gallagher.com/clean_records.htm
    I have found this method to work pretty good, what it won't do (including the $500 machine) is remove clicks and pops from scratches. If the record is in good shape this method provides very good results.
    2-Channel System
  • nspindel
    edited May 2013
    Not true. A great deal of pops and clicks are actually the result of dust and grime embedded in the grooves. I have purchased vintage records that look really good and scratch free, but when I play them there were tons of clicks and pops. Then I cleaned on the VPI and the background noise disappeared.
    I cannot emphasize this enough. Knowing what I know now from my own experience, if I still had my Thorens with the $75 cartridge, but I didn't own the VPI 16.5, and you handed me $600 to improve my vinyl rig, I would definitely spend that money on the good record cleaning machine and the brushes and solutions, I would not put that cash into a better table or cartridge.
  • hochpt21
    edited May 2013
    I think the "from scratches" part is the emphasis.
    When I first got into vinyl, I thought that a scratched record could be "cleaned." Boy wouldn't that be something.
  • nspindel
    edited May 2013
    Fair enough. But alternatively, until you clean the record, you don't know if the noise you're hearing is from scratches or from dirt. Point being, you shouldn't underestimate the contribution a RCM adds to the quality of the sound. I have literally been blown away by the difference in sound before/after cleaning.
    Here is my recommendation:
    http://www.elusivedisc.com/VPI-HW-165-BASIC-RECORD-CLEANER-PACKAGE-609/productinfo/HW%2D165P1/
    The machine is packaged with the fluids and one brush, plus an extra mat and anti-static sleeves. If you sit tight and wait for one of elusivedisc's 10% off sales, you get all that for about $550. Subtract the value of all the extras, and the machine ends up costing net around $450.
  • dromunds
    dromunds Posts: 10,164
    edited May 2013
    Regarding phono stages, I recently bought a Parasound zphono used for a buddy for about $100 shipped that wanted to get back into vinyl and had a very limited budget. I was actually pretty surprised at how good it sounded.
  • hochpt21
    edited May 2013
    nspindel wrote: »
    I 100% agree.
    I even got my wife to buy me a Nitty Gritty for my birthday a couple years ago. I still don't know how I managed that!
    There is a $200 vacuum RCM over at AudioAdvisor. I don't know how good it is, but seems to be similar in specs to my Nitty.
    SCompRacer Posts: 9,274
    edited May 2013
    Fellow ESL owner, don't do it...:biggrin:
