RT55i vs RTI70 as rear speakers
Sydney's Dad
Looking to upgrade the reae speakers. What speaker would sound best with the RTi150's and the CSi40?
Sony 53" TV
Sony DA777ES Receiver
Sony SCD-C55ES CD/SACD
Sony DVP-NS755V DVD
Sony 4-TA-N55ES Amplifers
Front 2 pair Polk RTi150
Center Polk CSi40
Rear Polk RTi70
Sub SVS PC+ & Infinity BL-2
Sony DVP-NS755V DVD
Center Polk CSi40
Rear Polk RTi70
Post edited by Sydney's Dad on
If you're ridding yourself of the CS400 and replacing it with the CSi40, presumably for continuity's sake, why would there be any question? Get the RTi70's and remain uniform.
Which speaker do I prefer of the two? The 55i.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
Do you ever use your rt55's as part of your home theater setup? I take it you prefer your rt800's over the rt55's in HT?
I'm looking to p/u either the rt55's or the rt800's. Whichever I find first I'm gonna buy.
Thanks,
SpyderRTi70 Fronts
CSi40 Center
RTi38 Rear
PSW650 Sub
Str-de1075 Receiver
Hope is on the way!
ABB -
I've never run the 55i's in the home theater. I'm guessing that the differences between them won't manifest themselves as clearly, given that they're crossed over at 80Hz. If it's strictly home theater that you're using the speakers for, I wouldn't worry about it at all, they'll both perform very well.
Two Channel Setup:
DAC: Arcam irDac
Source: iMac
As rear speakers, the RT800's won't require stands. The RT55's will. Also, the bass extension (if set to large) will be superiour with the RT800's.
I use the RT800i's as rear surrounds with Monitor 10's in the front in my HT. The RT800i's work fabulous in this setup.
Both are excellent speakers. -
The quest is over. Just got back from CC with a pair of RTi70'sSony 53" TV
Sony DVP-NS755V DVD
Center Polk CSi40
Rear Polk RTi70
