Can I pair rti6 bookshelf with om3 and om5?
palgaurav
palgaurav Posts: 1
edited May 2013 in Speakers
Hi,
I have a pair of rti6 bookshelf speakers, and just love the sound. I am building out a home theatre now, and need to get surround and center channel speakers. My budget is limited as well, hence i need to investigate some "non standard" options.
I want to use the rti6 as the front speakers, om3 for the surround, and om5 for the center channel. Can anyone advice if this can work?
Thanks,
-Gaurav
Post edited by palgaurav on
  • Jimbo18
    Jimbo18 Posts: 2,348
    edited May 2013
    I think most people here will tell you that the center channel should timbre match the front speakers as much as possible. The surround, if money is an issue, isn't as important to match the front.
