ready to pull the trigger
soundfreak1
Going to ( finely) do my RTA12C'S. Qurstion! What alterations need be made to accomadate the rdo198's physically and electronicly???
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Post edited by soundfreak1 on
the RD-0194's are the designated replacement for these, not the 198's. As far as mods to the Xover, I don't believe any are required.
The 194 is a little larger than the SL1000 so you'll have to enlarge the hole in the board at mounts on."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Mine already have had the 194's now, intend to upgrade to 198's when doing the xovers.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
I believe you will have to make some changes to the crossover if you change to those tweetsHome Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
^^^ +1
I don't recall anyone using the 198's in RTA 12C's. On other Polk speaks, using the 198's typically requires the addition of a cap (or change in value of one of the existing caps) along with a change in resistor values.
Have you already upgraded the Xovers? If not, I would start there."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Not done yet! Getting ready to order parts which is why i need the info as to what changes in the current caps or risistors i need to change for the 198's.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
