hurricane nuts
canadianicon25
canadianicon25 Posts: 200
edited May 2013 in Vintage Speakers
is there another name for these? i am trying to find a place that has them other than parts express. the shipping to Canada is brutal!
Post edited by canadianicon25 on
    F1nut Posts: 51,999
    edited May 2013
    Not that I'm aware of.
    They are available on Amazon and eBay.
  • Schurkey
    Schurkey Posts: 2,122
    edited May 2013
    Tee nuts/prong nuts are similar but not identical. Should be available anywhere--local hardware store for example.
    http://www.amazon.com/Prong-Nut-8-32-Tee-Qty/dp/B00BOEKQSM/ref=sr_1_1?ie=UTF8&qid=1369594403&sr=8-1&keywords=Tee+nuts+8-32
  • PolkieMan
    PolkieMan Posts: 2,446
    edited May 2013
  • heartystatue
    heartystatue Posts: 329
    edited May 2013
    I think they have a fastenal in Canada. They will have them.
    HT: LSI15, LSIC, LSIFX, Emo XPA-3:biggrin: Onkyo TXNR809, Sony BDP-S500, PannyDMP-BDT320, MIT S1 SC. Mit 73842dlp
    2ch: SDA-SRS 2.3 Fully modded. BAT VK500 w/batpak, BAT VK5I, Essence HDACC.
  • oldmodman
    oldmodman Posts: 740
    edited May 2013
    Those are available at every Home Depot and Orchard Supply I have ever been in.
    F1nut Posts: 51,999
    edited May 2013
    oldmodman wrote: »
    Hurricane nuts or T-nuts? Big difference and I would not recommend T-nuts for speaker basket mounting, but they are great for spikes.
  • drumminman
    drumminman Posts: 3,396
    edited May 2013
    ^^^ +1
    H-nuts are smaller and will work much better.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,204
    edited May 2013
    The prongs on the T-nuts will more than likely bend instead of penetrating the MDF. I know because I tried installing them and they didn't work well at all. I ended up cutting off the prongs and used liquid nails to hold them in place...what a pain in the ****. A much better alternative is to use hurricane nuts as others have recommended.
    SDA SRS 2.3TL's
    SDA 2B TL's
    F1nut Posts: 51,999
    edited May 2013
    Michaeljhsda2 mentions MDF. It should be noted that the bezels of all SDA's up to the TL verisons are particle board, only the TL versions are MDF. Regardless, T-nuts have to be driven in with a hammer and that is NOT what one wants to do on the flange of a driver cut out.
    Hurricane nuts are designed to be drawn in and should never be hammered in. To draw the H-nut in use a screw/bolt with a washer. Place the H-nut at the rear of the hole, run the screw/bolt into the threads and slowly tighten until the H-nut has setted.
  • canadianicon25
    edited May 2013
    went with t-nuts because they are locally available. yikes! hard to set. burned through cap screws and even a stainless bolt trying to set them in without clamping of any kind. didn't destroy the cabinets but wasted materials. i would def'n say that something other than t-nuts should be used. i went for the cheapest solution, but am wondering if it would have been better to just spend a bit more and ordered the hurricanes.
  • Schurkey
    edited May 2013
    Most stainless bolts are weak. About the equivalent of hardware-store Grade 2. Total junk for anything structural.
    http://www.ebay.com/gds/stainless-bolts-usually-very-weak/10000000001623345/g.html
    What grade of cap screws were you using?
  • drumminman
    edited May 2013
    You're making it too hard on yourself!
    Get H-nuts, drill out the existing holes in the front baffle to the diameter of the H-nut shaft (but not the wings of the shaft, in other words don't make it too big), press the H-nut in by hand just enough for it to hold, use your screw (preferably allen head) to draw it into place.
  • TennMan
    TennMan Posts: 1,266
    edited May 2013
    H-nuts make a better looking job if you take the time to break off about 1/3 of the radius of the flange. It keeps the flange from hanging over into the hole where the driver mounts.
    Easy to do if you have a bench vise. Just clamp the part of the flange you want to remove into the vise, then rock the nut back and forth with a long screw screwed into the threaded hole. With a little bit of rocking the flange will snap right off. Hit it a couple of licks with a file to knock off the rough edges and your done.
  • canadianicon25
    edited May 2013
    i don' know what grade cap screw. alloy steel of some kind; the only kind i could find locally in a 1" length. all i have left is the passive radiator on one speaker so getting h-nuts isn't worth it now. the h-nuts are cheap but the shipping was a lot. i saved money in the long run, but gave me the sweats working with them on vintage cabinets.
    F1nut Posts: 51,999
    edited May 2013
    I have to ask, how much would have been the cost of shipping?
    Time is money and aggravation is costly. By the sounds of it, you didn't save a penny........just saying.
  • canadianicon25
    edited May 2013
    approx $25.00 for shipping.
  • jon s
    jon s Posts: 905
    edited May 2013
    Don't use T-nuts! I have built two subs and in both cases, one of the T-nuts popped out of the rear of the baffe, rendering them useless. The problem is once they pop out, you can't get the bolt out!
  • TennMan
    edited May 2013
    What? That is brutal. Or highway robbery. Below are the details of my order for h-nuts from Amazon.co. 50 per box.
    Items Ordered
    Price:$5.50 - 2 of: #8-32 Hurricane Nuts 50 Pcs.
    Condition: New
    Sold by: Parts Express
    Item(s) Subtotal: $11.00
    Shipping & Handling: $5.41
    Total before tax: $16.41
    Sales Tax: $0.00
    Total for This Shipment: $16.41
    F1nut Posts: 51,999
    edited May 2013
    Yeah that's pretty crazy, but not as bad as the $122.00 I paid in shipping for some spikes from abroad. Sometimes you have to pay the piper to get what you want.
  • teekay0007
    teekay0007 Posts: 2,288
    edited May 2013
    Therein lies the problem. Of course you're more likely to pay more for spikes from abroad. Should have looked into getting them from adude.
  • PolkieMan
    edited May 2013
    Soooo if a dude looks like a lady then you must be pretty abroad minded :cheesygrin:
    teekay0007 wrote: »
  • jon s
    jon s Posts: 905
    edited May 2013
    You guys in Canada don't have it as bad as people in Hawaii and Alaska. I had to ship an amp for repair to St Louis, MO. The shipping charge was $500 round trip. I sent a broken Denon DVD player to NJ, and that was $250 one way (they paid for the return)....
    I also bought a couple of subs and plate amps from Part Express, about 75 lbs total. That was about $500 shipping via UPS ground.
