Lsi9 as a substitute for a LsiCenter
Ducati Guy
Ducati Guy Posts: 160
edited May 2013 in Speakers
Anybody ever try this since it's very hard to find an LsiCenter?
It should be the same right?
Post edited by Ducati Guy on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited May 2013
    If you have other LSi speakers for the fronts - should be fine.
  • nme medic
    nme medic Posts: 98
    edited May 2013
    ZLTFUL wrote: »
    The 9 is a great substitute for the LSiC...and a pair of them is even better!
    But then I have a pair of LSiCs so I don't have to worry about it. MWUHAHAHAHAHA! :cheesygrin:
    Seriously though, as a substitute for the C, the 9s are fantastic...maybe even a bit better as they tend to handle bass quite a bit better because of the larger cabinet.
    How do you have the pair of LSiC's hooked up? Also how does it sound? Do you just have them side by side?
    F:L/R LSi 15
    Cen: LSiC
    Sur: LSi FX
    SurBack: LSi 9's
    Sub: Modded PSW1000
    Sony STR-DA4400ES
    Emotiva UPA-200 W/Black Trim
    Emotiva XPA-3 W/Black Trim
    Samsung PN58A650 Plasma
    Plasma TV Wall Unit SKU: SH-CAESAR-WU
  • nme medic
    nme medic Posts: 98
    edited May 2013
    It's about damn time:cheesygrin:
    F:L/R LSi 15
    Cen: LSiC
    Sur: LSi FX
    SurBack: LSi 9's
    Sub: Modded PSW1000
    Sony STR-DA4400ES
    EndersShadow Posts: 17,690
    edited May 2013
    nme medic wrote: »
    I dont think he has both of em hooked up he just has 2 from all the LSi's he bought, he bought 2 full 5 channel sets of speakers.
    You might be able to buy one off of him :smile:
  • MikeC78
    MikeC78 Posts: 2,315
    edited May 2013
    Personally, I'd rather have an LSi9 center over an LSiC. Theoretically, your LCR should match, so if you have LSi9 mains, it would be the perfect match.
  • MikeC78
    edited May 2013
    ZLTFUL wrote: »
    Hehe. I don't currently have them both hooked up but am considering mounting my second one above my TV and just running a splitter from the single out on my AVR to both channels of one of the GFA-555s. But not sure I will even do that. Hehe.
    Ryan- Not a good idea.
    The only advantage of dual center channel speakers is an additional 3 dB of potential output. But you also add a plethora of comb-filtering, lobing, cancellations, difference in arrival times, phase problems.
  • pearsall001
    pearsall001 Posts: 5,247
    edited May 2013
    The LSi9 if mounted upright would actually be a better choice as a center. The ultimate front end L/C/R should all be matching. The center as we know it today was designed due to ease of placement.
  • eclypse
    eclypse Posts: 595
    edited May 2013
    I've seen pics online of dual LSi9s for the center channel on there side. Hunt for them. I would of done the same if I would of went with the older LSi setup over the newer LSiMs.
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
  • Ducati Guy
    edited May 2013
    I've got Lsi15's and plan to get the Lsi9 for the center and lay it on it's side.
    Would it matter if the Lsi9 is laying down vs standing up?
  • pearsall001
    edited May 2013
    Ducati Guy wrote: »
    Yes!!!!! The LSi9 is not designed for horizontal placement. Hence the design of the LSi center. Though not perfect it will perform better than a 9 placed on it's side. You run into all sorts of problems with a speaker designed for vertical placement that is used horizontially. If you can't use the 9 in it's designed placement then use the LSi center.
