RTA 12B sensitivity
laotzu61
laotzu61 Posts: 327
edited June 2013 in Vintage Speakers
anyone know what the sensitivity (in db's) is of the rta 12b's is?
thanks.
"The symbol is not the reality"
Post edited by laotzu61 on
    pitdogg2 Posts: 25,685
    edited May 2013
    88-90 guessing
  • Mystery
    Mystery Posts: 2,546
    edited May 2013
    More info here but it doesn't specifically mention sensitivity:
    http://www.polkaudio.com/forums/attachment.php?attachmentid=26121&d=1183714959
  • laotzu61
    laotzu61 Posts: 327
    edited May 2013
    thanks for the input. I have that pdf printed out, mystery. it seems as tho I read 88db somewhere at some point, but i'm not sure.
  • jon s
    jon s Posts: 905
    edited May 2013
    While efficient, the RTA-12s require a high current amplifier in order to get the best performance out of them. I had a 100-wpc amp that was lightweight. Sound was horrible. I connected the speakers to a Acurus DIA-100 (also 100-wpc, but with a bigger power supply) and it was a magnitude increase in sound...
  • drumminman
    drumminman Posts: 3,396
    edited May 2013
    They're rated 4 ohms nominal impedance, and can be driven with 10-500 wpc. The lower number suggests good sensitivity, but I would definitely go with as much clean, high current power as you can muster. It makes a huge difference in SQ.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited May 2013
    +1 on the current requirement. My pair didnt wake up under 200w and high currant, the c's are the same. I believe the senistivity is about 86 db. They like lots of power, and reward you for supplying it!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    F1nut Posts: 50,753
    edited May 2013
    They are in the 90 to 92dB range.
  • laotzu61
    laotzu61 Posts: 327
    edited June 2013
    thanks much for the info, guys.
