SDA's and low ceilings?
bored184
bored184 Posts: 324
edited May 2013 in Vintage Speakers
Over the next two weeks my setup will slowly be making its way down the the basement/man cave. Its a fairly decently sized room however it has a much lower ceiling than my living room. I will get the measurements of room tonight. I should be able to set my SDA 1Cs up properly per the instructions but will the low ceiling cause any problems or damper the SDA effect.
Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Amplifiers: ]Ashly FTX 2001 III, Dynaco ST-70, DIY F6
Pre: Adcom GFP 750, Aikido Tube Pre
Post edited by bored184 on
  • Face
    Face Posts: 14,340
    edited May 2013
    You should still be fine.
  • chandler9a
    chandler9a Posts: 878
    edited May 2013
    My 1C's are in a room with the ceiling at about 8ft I would guess, they sound fine.
    Let us know what your measurements are but I think you will be fine as long as they are set up right.
  • nspindel
    nspindel Posts: 5,343
    edited May 2013
    I've had SDA's as big as 1C's in my basement with 7' ceilings. You're fine.
  • bored184
    bored184 Posts: 324
    edited May 2013
    We always talk about SDA's needing room to breath but I never thought of the ceiling as a factor until now. I didn't think it would have any affect but my curiosity got the best me so I decided to ask those of you who are much smarter than I.
  • bored184
    bored184 Posts: 324
    edited May 2013
    I just measured the room, its 16.5ft in length, 12.5ft in width, and just over 7ft in height. It current setup it vintage wood paneling, laminate tiles, and those white tile ceiling squares (not the drop down kind).
    F1nut Posts: 50,753
    edited May 2013
    Ceiling height does make a difference, but I think higher is worse than lower. Your room is going to be lively. Carpet, upholstered furniture and wall treatments will be a big help.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited May 2013
    Or you can get some old hides and put on the walls. :rolleyes:
    Wait a minute that's what we in Texas call our wifes , "old hide" :biggrin:
  • bored184
    bored184 Posts: 324
    edited May 2013
    That was the plan! I will be looking at Lowe's and a few other carpet places for a remnant large enough to cover most of the floor. Should I place the SDA's directly on the carpet or would it be better if place them directly on the tile? My original idea is to have the carpet come about 18-20in from the wall. This will give me a nice hard flat surface to place my speakers and audio stand.
    F1nut Posts: 50,753
    edited May 2013
    Personally, I'd go wall to wall, but whatever you decide spike those speakers and audio stand.
  • bored184
    bored184 Posts: 324
    edited May 2013
    I was thinking if I placed them on the tile it would be better then placing them on carpet. Spikes are in the game plan but not anytime soon. I want get the tweeters and XOs done first.
  • PolkieMan
    edited May 2013
    I would go wall to wall carpet and then something like what is on the ceiling for the walls.
    http://www.atsacoustics.com/cat--ATS-Acoustic-Panels--100.html
  • Schurkey
    Schurkey Posts: 2,104
    edited May 2013
    1. Might want to use a room node program to locate the best initial placement point for the speakers and seating. 7 foot X 2 = 14 foot--mighty close to the other two dimensions. Room nodes are going to be a problem. You're definitely going to need acoustic treatments.
    2. Be careful what you put on the walls. Carpet on the floor is bad in a fire--releases toxic gasses. Carpet on the walls will release additional toxic gasses, may be a fire hazard in itself.
    nspindel wrote: »
    My 1Bs are in a basement room with a 7-foot dropped (acoustic tile) ceiling; there's fiberglass insulation above the tile filling the floor joists.
  • bored184
    bored184 Posts: 324
    edited May 2013
    Schurkey wrote: »
    I have been looking at some room node programs but I am horribly confused as to the results. Is their a good free one out there that also explains some of the results I am looking at.
