Blue Jeans Cables Ten White
zingo
zingo Posts: 11,258
edited May 2013 in 2 Channel Audio
Last week I bought a pair of Blue Jean Cables Ten White speaker cables. These are their signature speaker cable constructed out of their own Belden 5T00UP 10AWG cable, and terminated with locking banana plugs that are ultra-sonically welded on; no solder to my understanding. I haven't put the cables through their aural paces yet, but the cable is solid while not being too still, and the plugs have a rediculous physical and electrical connection with the welding.
The cables are reasonably priced as it cost me about $70 for 7ft of paired cable; I picked them up from the shop so no shipping. They aren't the cheapest, but the ultra-sonically welded, locking banana plugs are worth a pretty as you will never have to worry about them, and the 10AWG wire is always good insurance against resistance.
I recommend these as a solidly built speaker cable at a solid price!
Post edited by zingo on
  • Conradicles
    Conradicles Posts: 6,375
    edited May 2013
    I run them and love them. My top budget choice.
  • Face
    Face Posts: 14,340
    edited May 2013
    Great cables, but too bad they don't use copper based termination. I'd recommend either Vampire copper based spades or if you want to go all out, WBT. For those who use Speakon connections, this wire is too thick.
  • ken brydson
    ken brydson Posts: 9,020
    edited May 2013
    PatFox wrote: »
    these are really fabricated with absolute price on its list. superb one to shop with style and passion
    WTF does this mean?
  • zingo
    zingo Posts: 11,258
    edited May 2013
  • brianle
    brianle Posts: 572
    edited May 2013
    what's your impression comparing to other speakers cables you have tried?
  • zingo
    zingo Posts: 11,258
    edited May 2013
    I think they are good cables. Having owned 10AWG cables before, these are the smallest diameter jacket ones, which makes routing easier. There is nothing exotic about them, except maybe the welded connectors, but they simply seem to be every you need. Now, take this from a guy who enjoys a pair of MIT cables as well, and I do think they are worth the money as the aural gains are impressive. But, high prices and esoteric technology/designs aside, it's hard to beat these in the under $300 category.
  • brianle
    brianle Posts: 572
    edited May 2013
    Thanks. Is there any negative, sound wise, about them ?
  • zingo
    zingo Posts: 11,258
    edited May 2013
    I'll do some more listening tonight and let you know.
  • zingo
    zingo Posts: 11,258
    edited May 2013
    For speakers cables, you can't go wrong with all BJC White. They are not my preference for signal cables though. Whether RCA or XLR, I think there are best options for the price; my favorites are from DH Labs.
  • Systems
    Systems Posts: 14,872
    edited May 2013
    You should look at the Rivercables for the money.
    The Flexgy speaker cables in particular (both 6 and 8).
    Even the 6's are KILLER!:eek:
    Especially the Flexygy 8's though, really, really good bang for buck!
    Not cheap new, but can be had used on the cheap and will SMOKE most I have heard, for the money (@ the used price).
    Really an excellent speaker cable, and can pretty much beat my Nordost speaker cables!
    OUTSTANDING SC for the money!
    Do a search!:cheesygrin:
    Testing
    Testing
    Testing
  • Systems
    edited May 2013
    I have owned both the 6 and 8's, still own the 6's, and will most likely have at least one pair of Flexgy on hand at all times.:eek:
    That said, I have owned more than my share (including the BJ 10 ga. cables), and unless you want me to go into to the next 3 pages listing all the speaker cables I have owned, I suggest you look for a used pair of the Flexygy.
    Easy Google Search!:cheesygrin:
    Testing
    Testing
    Testing
  • zingo
    zingo Posts: 11,258
    edited May 2013
    Without doing some serious A/B testing of wire and connectors (it does make a difference), there is nothing about the sound of the BJC White Ten that I don't like. As was stated previous, I wish the banana plugs were pure copper, silver plated copper, or silver plated junk brass, but other than being a little more "pretty", I think they are a good value for the price, and as much as 90% of audio consumers need.
  • Face
    Face Posts: 14,340
    edited May 2013
    I can't find anything wrong with them either.
  • zingo
    zingo Posts: 11,258
    edited May 2013
    And as a side note, the BJC shop was a messy disaster when I went there! :eek:
  • zane77
    zane77 Posts: 1,696
    edited May 2013
    Those Rivercables look really nice, may have to try a set
    Two Channel
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2013
    I'm looking on their speaker cable page and don't see how to order cables terminated with the locking banana plugs? I see the regular bananas listed, but not the locking. In fact on their website it even says that the locking plugs are attached using screws, I'm confused.
  • Face
    Face Posts: 14,340
    edited May 2013
    Yes, you use the two screws on the body to attach the bananas yourself. I don't see a "welded" option for them.
  • zingo
    zingo Posts: 11,258
    edited May 2013
    I was confused too until I called them. If you're ordering the finished speaker cables with banana plugs, locking and welded are standard. If you just order bulk banana plugs, they will have screw terminations for doing it yourself. It's not very well outlined...
  • Tardcore
    Tardcore Posts: 11
    edited May 2013
    The DIY connectors that they sell are (obviously) not sonically welded.
    However, if you buy a pre-made cable (select a cable length and connector type on the order form) they are sonically welded.
