Question about parallel resistors
nduitch
nduitch Posts: 316
edited May 2013 in DIY, Mods & Tweaks
I have two 1 Ohm resistors in parallel, why does my VOM still read it as 1 Ohm?
  • Face
    Face Posts: 14,340
    edited May 2013
    They could be out of spec.
    http://www.1728.org/resistrs.htm
  • nduitch
    nduitch Posts: 316
    edited May 2013
    According to that calculator, 2 x 1ohm resistors in parallel is 1 ohm. So that changes a lot in all those crossovers using 2 x 1ohm mundorf mox resistors in place of a 2 ohm resistor, if that is true.
  • blairfrischx
    blairfrischx Posts: 259
    edited May 2013
    How did you get the calculator to spit out 1 ohm for two 1-ohm resistors in parallel? It [correctly] says 0.5 ohm for me.
    Crossovers using two 1-ohm resistors in place of a 2-ohm resistor would have them in series.
  • nduitch
    nduitch Posts: 316
    edited May 2013
    Yes, 0.5 correct.
  • Face
    Face Posts: 14,340
    edited May 2013
    nduitch wrote: »
    What crossover is this?
  • Face
    Face Posts: 14,340
    edited May 2013
    Depending on where it is in the crossover, it may or may not make a significant difference. If it's in the parallel leg of a woofer crossover, before or after a cap, it will affect the woofer's roll off on the top end. Changing out to a smaller value will affect the woofer's top end roll off, making it roll off sooner. This may affect phase integration, possibly create a small hole or dip in response, and maybe even lower distortion. In other words, it may not do anything offensive and require a change, but I would need to see what speaker, and where in the crossover this value exists to confirm.
  • Phasewolf
    Phasewolf Posts: 513
    edited May 2013
    The leads of your DMM may add some resistance to what you measure good leads cost a lot and so does a a accurate DMM what are you using and when is the last time you sent it out to be calibrated?
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
  • nduitch
    nduitch Posts: 316
    edited May 2013
    I had the resistors wired in parallel, thinking they would double up. I wired them in series and the value is much closer.
