HDTV receiver crackling
edited December 2003 in Electronics
I hooked up my Hitachi 57F500 and the HDTV box last night and found that there is a slight crackling when watching regular def channels. It didn't happen when watching any of the HDTV channels. It also crackles when I output the sound into my polk set-up. I have a 75ohm cable from the wall into the box and the component cable/2 channel audio to the TV. I disconnected everything but the TV and Cable box to check for interference and it still crackled. I also then removed the 2 channel audio cables from the set-up and ran a Toslink cable from the box into my Denon. Completely bypassed the TV speakers and it still made the noise. The only thing I can think of is the box is screwed up or the cable into the house is bad. Anyone ever heard of this problem? Thanks!
Receiver = Denon AVR-3803
DVD = Denon DV-2900
Fronts = SDA SRS 2.3TL's
(Carver m1.5t)
Center = CSi40
Side surrounds = Fxi30's
Sony 12" sub
TV = Hitachi 57F500
Bedroom rig:
Pioneer SX-1050 receiver
Rti38's
Post edited by acdds on
    Turned out to be a bad box. Switched it for a new box everything is great. Thanks!
    DVD = Denon DV-2900
    (Carver m1.5t)
    Center = CSi40
    Sony 12" sub
    TV = Hitachi 57F500
    Bedroom rig:
    Rti38's
Welcome!
Welcome!
