Hooking up an amp from Thailand
polkfarmboy
polkfarmboy Posts: 5,703
Will there be a problem with the voltage on an amp from Thailand running through the US power. If there is then is there a way to fix it, my old yaqin came from china and it worked fine
    gudnoyez Posts: 8,210
    edited May 2013
    I bet there is a voltage selector switch, what do they run in Thailand? I own a lot of gear That I bought in Europe and the voltage selector switch is built in.
    nooshinjohn Posts: 26,124
    edited May 2013
    How much would it be to send over 2 hot 20 yr old ladyboys in a 4 by 4 foot wooden shipping container? I would pay for the bottled water, bread and cat litter of course
    You could always ask your ladybois in skinny jeans to hook you up.
  • polkfarmboy
    edited May 2013
    anonymouse wrote: »
    Thailand is on 220V. You will need a step up transformer. Make sure you get one with enough juice.
    Is there versions that can accommodate up to 3 devices ?
    Here is the specs advertised for a preamp I want 220 240V±5%, 50Hz/60Hz
    I have been trying to contact the seller to talk about it and maybe cancel my order as the item would have no resale value once I would want to move on
  • decal
    decal Posts: 3,205
    edited May 2013
    Why don't you find out about these things before you order something? Just curious.
  • polkfarmboy
    edited May 2013
    I got carried away by the good prices
    pitdogg2 Posts: 27,828
    edited May 2013
    Hence the very good reason to investigate closer. One thing i remember from long ago prices at 6th ave.electronics was they imported Yamaha Gear that was much cheaper than any other place in the U. S. BUT they had not been built for U.S. sale so they did not have any UL approved listing and some of those items caught fire when used here....
    there is an old saying you should remember forever......Starts out with "If it's too good to be true"
  • Glen B
    Glen B Posts: 269
    edited May 2013
    Step-down transformers, even ones rated up to several kilowatts, are not expensive. One that is 2-3 times the maximum power consumption of the amp and other equipment you are running should work just fine.
    Step-down transformers 100W to 15kW
  • polkfarmboy
    edited May 2013
    There is also another saying 'Never look a gift horse in the mouth' lol
  • polkfarmboy
    edited May 2013
    Glen B wrote: »
    Here is a pair of amps I would love to run from spain http://app.audiogon.com/listings/tube-melody-pure-black-88-monoblocks-2013-04-24-amplifiers-spain
    edited May 2013
    Well you got me there But a gift means you spent no money.....So if this gear if free from Thailand then hop on that train....To my way of thinking you're going to need one more item in that chain that could induce noise...
