is this overboard
leftwinger57
leftwinger57 Posts: 2,917
edited May 2013 in Speakers
Hi guys,
For some reason I still have a hard on for a pair of Vandersteen 2ci . Now the 2ci have the butyl surrounds which are way better than replaceing aging foam surrounds. When speaking to the dealer he said the stands are a must which I have heard is a necessity to get that correct height to ear ear level. Speaking of levels he asked me if I had both a torpedo line level which I do and a lazer level and do not . Here's where the question comes in does one need a lazer level to adjust a pair of speakers that are going to be 7' apart horizonitally w/ the adjusting the stands. It just seems like over kill to me.
He also said to bi wire them and ditch the speaker selector deal.I would if and when I get the speakers that will be the end of the road for me.
    F1nut Posts: 51,684
    edited May 2013
    You don't need a laser, a tape measure works perfectly.
    Just replace the stock jumpers with some high quality speaker cable. MIT sells an excellent set of jumpers for about $100.00. Definitely ditch the selector.
    tonyb Posts: 33,066
    edited May 2013
    Agreed ^^
    "end of the road" ?? No such thing LW. :smile:
  • zingo
    zingo Posts: 11,258
    edited May 2013
    This should do it for you; Jesse scores again!
  • Bob in WI
    Bob in WI Posts: 155
    edited May 2013
    The Vandies definitely have a sweet spot & the vertical dimension is important The difference between 32" & 48" from the floor makes an easily audible difference in quality. Also, not too close to a wall/ they need to breath some. You do need the stands. I got mine used & am very pleased. They like power - 100 watts wasn't cutting it. Hope this helps. Good luck with your choice.
