Floor standing Speakers for Music only
jumpindick
jumpindick Posts: 428
edited May 2013 in Speakers
I have been thinking about setting up a dedicated music system. I would be using tube amp to drive them. Amp would be Yaqin MC-13s. I would be strickly using this for music only since I already have dedicated HT system which include RTiA9s.
I have tried using RTi A9s for music, but did not find that good warmth that I was looking for. Budget is about 1500.00. I went for an audition and the salesman was trying to sale either Paradigm Studio 60 or Monitor Audio RX8. Well they are a bit pricy.
I have been reading about the speakers and seems to be getting more confused. The ones that I find highly rated, they don't fit my budget.
I would really appreciate any help you guys can provide ... Any suggestion.
Post edited by jumpindick on
  • zingo
    zingo Posts: 11,258
    edited May 2013
    The best music speakers for $1500 you will find are probably used. Do you have good options on Craigslist? Take it from me, custom built speakers can sound much better than they can be sold for; a great value for the money. For that amp, maybe a pair of KEFs or vintage Klipschs?
  • falconcry72
    falconcry72 Posts: 3,580
    edited May 2013
    Yep, go used.
    Magnepan 1.7's, Polk SDA's, and Polk LSiM-705's or 707's would all have my attention. :)
    The Maggies might not do great with that amp though.
  • zingo
    zingo Posts: 11,258
    edited May 2013
    Not convinced a pair of LSis would be great with that amp, but SDAs should be tasty with the KT88s.
  • Irrenhaus
    Irrenhaus Posts: 1,102
    edited May 2013
    I have a pair of Linn Keilidh using a Parasound and love their sound, but not sure how they will pair with that amp. Also sometimes I use a pair of ADS L690.
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited May 2013
    When I auditoned some used Vandersteens 2ce sigs I was pretty impressed. Used that would work for your budget.
    tonyb Posts: 33,072
    edited May 2013
    Here's how I see it. If floorstanders are your thing, especially big ones, then you may need to go with a tubed pre and SS amps. Not saying that a tube amp can't do the job, just not at the level your at. Second, better cost more, your just going to have to swallow that. Third, yes...good deals on the used market can make some top gear within your reach. Since we can't listen with your ears, we can only suggest what we have heard and liked. For me, Legacy, Emerald Physics, PBN Montana, Totems, JM labs, Joseph, Salk....which btw is a great speaker for the coin. I'm sure there's more but find a speaker with the sound characteristics you like and tweek it with the associated gear and cables. Don't give up on a speaker so easily, their sound can change dramatically when given proper buddy's to play with. Just my .02
    Too many of us have spent a small fortune and a huge amount of time chasing our tails in this hobby. Buy what you want and just enjoy the music. If your always focused on the next best thing, you'll never stop and this audio thing will start to become more of a nuisance than pleasure.
  • jumpindick
    edited May 2013
    Guys, I am happy to see such constructive feedback/support. I really appreciate it. I guess the main reason I am more confused and indecisive is that this is my first tube amp. At this point, I did not want to spend too much money. Thanks to Darren, I got the amp at great price.
    I guess the next right thing to do is to audition some. I was just trying to pick y'all's brain since I am still a newbie with tube amp. I was hoping to get some direction as far as type of speaker that might fit with this amp, although I totally agree that I am the one who will have to listen to decide. But thanks again for the help. Much appreciated.
    nooshinjohn Posts: 25,928
    edited May 2013
    tonyb wrote: »
    High powered tubes get the job done as well or better than many SS amps do IMHO.
  • Bob in WI
    Bob in WI Posts: 155
    edited May 2013
    When I auditioned some used Vandersteens 2ce sigs I was pretty impressed. Used that would work for your budget. Got a pair with stands for $300 off CL several weeks ago. Nice neutral speakers. I just upgraded from a 100 watt NAD to a 200 Watt PS Audio amp & they responded nicely to the power (better quality amp too). My impression is the Vandies may not be the best rockers available. But they make acoustic & orchestral music come alive for me. Hope this helps.
  • jumpindick
    edited May 2013
    Bob,
    Sure it helps. Thanks buddy. Much appreciated.
  • pretzelfisch
    pretzelfisch Posts: 160
    edited May 2013
    There is a pair of LSiM 705 on sale at the Polk ebay store for $2,166 a pair. If you want to stretch your budget a little.
