Outlook users..need help...
starkiller
Anyone know how to delete a contact? You know, when you don't remember a person's addy and you key in the first letter of the address and it gives you a bunch to choose from that you have used before? I want to delete one of the choices it gives you...can you do that??
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
Didn't work, i highlight it and do the delete button the keyboard and nothing..tried shift/delete and control/delete also...Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Highlight and then the delete key is the way mine worksHome Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Actually open up the contact. At the top of the page there is a delete button... CLICK ITWhere’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
Are you emailing your girlfriend and you don't want your wife knowing?
LOL!!!!!!!!!!!
Sal I laughed quite hard when I read this... Must be the few beers in me. -
Did like you wrote, use arrow down, hit delete and zilcho, nada, zip happens..and no, not a girlfriend..my dad's email address that he used until he passed away in 2009, thought it was goneComputer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
What version of outlook are you using? This is how it works with at least 2007 and up (heck 2013 actually has a delete 'x' beside the email to remove it from that list). You may be on like 2000 or 2003. I can't remember if those ones let you delete or not, been quite a long time since I've used them.
Edit: looks like it should work in 2003 as well from this link: http://email.about.com/od/outlooktips/qt/et_del_autocomp.htm
If you have 2003+ then you may want to look at Ingressor (on the link above) as it will allow you to edit the auto complete file. Hope this helps. -
It's the version i got when my Hotmail was changed over to Outlook....Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
That may be Outlook Express, I don't know if it is different than Outlook Exchange that I am using.Home Theater
Two Channel
Soooo, your talking about the web page, Outlook.com, and not the actual outlook web mail client from MS Office. Check, I'll take a look at mine and see.
I think you need to click the arrow next to where it says outlook on the top left of your screen, and then choose people. You should be able to check contacts you want to remove there and then simply click delete at the top of the screen.2007 Club Polk Football Pool Champ
"It's like a koala bear crapped a rainbow in my brain!" -
jflail2
You be the winner! Worked perfectly and to be honest i should have known what to do but obviously i didn't know. Will try and investigate more thoroughly in the future:redface::redface:Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
