Modified PS Audio Trio C-100 Integrated Amplifier
markmarc
After five years in my stable of reference review gear it's time to move on. Therefore, I'm selling my very minty Trio C100 for $850 + shipping(last new price was $2000. Rarely found on the used market, the modifications were designed and done by the actual designer of the stock model Rick Cullen. Below are the various modifications. You can read my review of the unit at: www.affordableaudio.org/aa2008-01.pdf. The unit ships in its original box with remote and manual. The actual amount of usage is right around 400 hours, as it was never the main amp, but a reference sound unit when comparing with ICE power. I had no problem driving my Magnepan 1.6's which create difficult loads, though I didn't find it an absolute terrific match.
Payment is by Paypal, shipped from 97223. Box measurements and weight will be posted this evening.
Former Staff Member TONEAudio
2 Ch. System
2 Ch. System
Post edited by markmarc on
any idea how it would sound paired to kef r series speakers. I am just wondering if this would be an upgrade from what I currently have which is rotel rb990bx rc990bx pre pro combo.
regards,
eduardoHT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES -
Eduardo:
Well, you're giving up 100wpc a side in a switch, and will come out ahead if you sell your combo. Having had a recent series Rotel in my home (1520 integrated), I would venture to say the Trio C100 will have blacker blacks. The key to ask yourself is whether the KEF's and you need such power.Review Site_ (((AudioPursuit)))
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
UPDATE
Shipping info: The Modded Trio C-100 comes double boxed, measurements 21" x 13" x 7", shipping weight 14 pounds.
Modifications made by Rick Cullen:
Installing Cullen Circuits modified gain cells. Each Gain Cell upgrade (there are 2) includes the following:
Replace 28 resistors with Dale Rn55d copper leaded parts. These are all matched to .1%.
Replace 3 semiconductor devices with upgraded parts yielding an improved bandwidth and decreased har- monic distortion.
Replace two lectrolytic capacitors with audio-rade Muse caps.
There are a total of 66 new upgraded parts in the Gain Cells alone. Once modified, Rick perfectly matches them.
Replace 12 resistors on the main board with Dale Rn55d copper leaded parts.
Install 4ea WBT 0765 insulated output binding posts.
Install 2ea WBT- 0210cu ms Next Gen Signature RCA jacks on the #1 input
Wire the speaker outputs with Kimber TCX 15 AWG multi gage/strand OFC wire.
Install ERS EMI/RFI suppression paperReview Site_ (((AudioPursuit)))
2 Ch. System
