Quick question
NJPOLKER
Can I hook my TV to my old Marantz receiver then to my PSB Alpha Towers? Two channel of course but should sound better than the TV alone.
If I can what should be hooked up where? I'd guess TV audio out put to a input on the back of my receiver
I'm hoping to get it hooked up prior to my girl catching me hooking it up please hurry!!
Post edited by NJPOLKER on
If your tv has IC inputs then yes you can.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Its a new LG so it must thanks young lady
Where on the receiver should I plug the TV? Tape? Phone? Does it matter? -
I had to plug the receiver into the cable box to AUX and it works and Anne Marie is fine with it. I am the King.
The Marantz look sexy too but not as sexy as Anne Marie looks :razz: Much better than the TV speakers -
You got it right. Better to connect directly to the cable box instead of the TV. Enjoy.
Ditto on plugging into the cable/sattelite box. Do not plug into the Phono.
I had a nice 7.1 system. I sold it all and went two channel and have never looked back. When I am not watching TV I can listen to music on the two channel. Btw get a turntable and then use the phono input!I got static in my head
