RT 7 Tweeters
USVI
USVI Posts: 2
edited May 2013 in Vintage Speakers
I am new to the forum and need some help. I have a pair of RT 7 speakers in need of replacement tweeters. I have read that the original 6501 drivers are no longer made. What is the model number of a suitable replacement for these?
Thank you in advance.
Post edited by USVI on
  • rooftop59
    rooftop59 Posts: 8,121
    edited April 2013
    I think your gonna have to scour the internet/eBay as there is notruly suitable replacement other that the original. Rt7, rt16 have same tweeter, rt25i, 35i, 55i, 800i have a very similar tweeter, but those are difficult to find used. Good luck!
    Game Room 5.1.4:
    Bedroom 2.1
  • StantonZ
    StantonZ Posts: 452
    edited May 2013
    This is one of those rare instances where having something OLDER (Monitor series) is actually easier to repair/replace.
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • Tbone289
    Tbone289 Posts: 661
    edited May 2013
    SL-6501 tweeters can be found on Ebay from time to time. Set up an ebay search to notify you when an auction is posted. Something such as "polk tweeter SL" ought to work. There are users here that will have those parts available also, but you will need to have 100 posts here in the forums to post a "wanted" ad.
    Another surefire way to get compatible tweeters is to buy a cheap pair of Polk RTfx speakers on ebay. They frequently go very cheaply, especially if the cabinets are rough, and one pair contains 4 compatible tweeters--SL6502. My understanding is that the SL6502 are identical to SL6501, except that they are magnetically shielded with a bucking magnet.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • rooftop59
    edited May 2013
    Here ya go:
    http://item.mobileweb.ebay.com/viewitem?itemId=281099693947&index=1&nav=SEARCH&nid=75400815135
    About the best deal you're gonna find for two of those tweets. Heck I'm tempted to buy it myself!
    Game Room 5.1.4:
    Bedroom 2.1
  • USVI
    USVI Posts: 2
    edited May 2013
    Thanks, my bid is in.
  • Tbone289
    Tbone289 Posts: 661
    edited May 2013
    The LS/FX uses a different tweeter. That is the tweeter used in the CS350LS and the LS 50/70/90 series. They will physically fit into your RT7s, but I don't know if they have the same specs and will sound the same. The RTfx is what you're looking for.
  • Tbone289
    Tbone289 Posts: 661
    edited May 2013
  • Systems
    Systems Posts: 14,873
    edited May 2013
    I have a pair BNIB if you are interested, along with a pair original woofers.:cheesygrin:
    Testing
    Testing
    Testing
  • Systems
    edited May 2013
    I would have to check, but I think the original tweeter is an SL6001 on the RT7's?
    I may be wrong, I will have to research, but if not, I have a pair of the SL6501's also!:cheesygrin:
    Testing
    Testing
    Testing
  • Tbone289
    Tbone289 Posts: 661
    edited May 2013
    RT7 Tri-Lams are definitely SL6501. The local schematic shows that model# and mine were confirmed when I did crossover upgrades.
  • locnguyen26
    locnguyen26 Posts: 34
    edited May 2013
  • GalaxyVortex
    GalaxyVortex Posts: 3
    edited May 2013
    I have a pair of RT7's with a rubbing voice coil on one woofer. They sound great. I am not sure if I should buy a woofer or sell the good woofer and two tweeters. I can't read or post the wanted or for sale posts yet. Any idea of the buy and sell price range these drivers are these going for?
  • GalaxyVortex
    edited May 2013
    I need to either buy an MW8002 woofer to replace my bad one, or sell my good one. Do you need to sell as a pair?
  • rooftop59
    edited May 2013
    best to check completed listing on ebay, but they do not come up very often. One tweeter just sold for 16 and change http://www.ebay.com/itm/Vintage-Polk-Audio-RT-7-Trilaminate-Balance-Dome-Tweeter-SL-6501-/140970102702?pt=US_Speaker_Parts_Components&hash=item20d2790fae
    Personally I think that they are great speakers and I would just do a saved search on ebay for the midwoofer or an individual speaker. It may take several months but one will come up for a good price...
    Game Room 5.1.4:
    Bedroom 2.1
  • GalaxyVortex
    edited May 2013
    Thank you. Tonight's update: I believe that I fixed the driver! Yesterday the distortion was so bad, I figured that I couldn't make it worse. I pulled off the center cap and "pushed" the voice coil cylinder sideways to recenter it and bring it back to round. So far, so good. It sounds sweet and clear like the other one now. Time will tell if this holds up, but I suspect that it will be fine.
  • So how's the rub now and how long has it been since ya tweaked the coil?
  • Need the 6501 tweets myself. Anyone know how the 6508 are by comparison?
