Dreadnought wanted
zane77
zane77 Posts: 1,696
edited April 2013 in Vintage Speakers
Okay, just picked up a BAT VK500 amp to power my week old to me, SDA SRS 2.3's. I think this will be a pretty good match but it is not a common ground amplifier so I thought I would check to see if someone had one they wanted to sell or had the transformer to build one that they wanted to sell. If not I guess I'll be looking to pick up a transformer from Avel. I know that there was a. Group buy on a little better one from them and was curious if someone had one laying around that they decided not to use. Thanks for the help
Two Channel
Post edited by zane77 on
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited April 2013
    I don't have one to sell, but one of my Dreadnoughts is made with a Toroid Corporation of Maryland transformer, and it works very well. It is only a 670VA transformer. They sell arger ones and deliver very quickly.
    Toolfan66 Posts: 17,333
    edited April 2013
    zane77 wrote: »
    2.3's or 2.3tl's? I don't believe you can use the dreadnought with the 2.3's. if the 2.3's are blade/blade then no you cannot use the dreadnought..
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
    F1nut Posts: 50,753
    edited April 2013
    The 2.3's are pin/blade.
    heiney9 Posts: 25,216
    edited April 2013
    I have an 800VA Avel that I bought from another member.
    PM me if you are interested.
    edited April 2013
    Thanks Jesse, I wasn't 100% sure.
    OP pick up the one from H9, it will do the job just fine.
    SVS SB16 X2
  • zane77
    zane77 Posts: 1,696
    edited April 2013
    Yeah, they are pin/blade
    Two Channel
