pioneer PD-59 stable platter CD player
pitdogg2
pitdogg2 Posts: 27,325
edited April 2013 in 2 Channel Audio
Has anybody got any good OR bad info on this player. Currently i used a Sony ES x33 that i completely recapped so I'm just curious how well the Pioneer stacks up both use 1bit dacs from what i can tell.
Ivan
Post edited by pitdogg2 on
  • headrott
    headrott Posts: 5,496
    edited April 2013
    Ivan, I have not used that particular Pioneer model CD player. I have have a transport with the same stable platter in it however. It is one of the best transport mechanisms I've seen/used and would recommend it based upond the transport mechanism stable platter). I cannot comment on the DACs, etc. in the player however sorry.
    edited April 2013
    headrott wrote: »
    thanks Headrott but i sure thought I'd get more responses as they were held in high regard or so I thought.
    So what stable platter did you have. I do remember some others using the stable platter but some didn't get it quite right from what i have read. gearing problems.
