Wireworld gold eclipse rca .. any opinions
polkfarmboy
I got offered a pair of these and would like to know if they are supposed to be any good in general ?
Post edited by polkfarmboy on
Are you asking if they're superior to Shotgun's or just in general?
Are you asking if they're superior to monoprice or just in general?
Just in general, if anyone has friends who owned them and had good things to say about them etc -
IMO, they're superior to anything else I've tried."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
You own them? or you got a demo?
Your opinion on this forum is way up there on my top 10 for credibility so that's a very reassuring statement about the gold eclipse. When I was looking into the shotgun then f1 h9 and a few other say that you need to have both ic and spkr cables to match. Would this be true about the wireworld series? -
Yes, I own them and use them in my main rig. I'd use them everywhere if they weren't so expensive.
Matching cables is more important with MIT's networked cables than anything else. That being said, I'm not a big fan of WW's speaker cables, only their interconnects and power cords."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I just bought a pair then shortly after I saw a used pair on agon for cheaper :eek:
I would rather have a brand new set anyway as I would always have the ' are they fake' question lingering in my mind, even if they were not and sounded awesome. Well now i need power cords and speaker cables to match or I just wont get the full potential out of these -
No, you don't need the other cables. IMO, their Aurora PC's are just fine, I wouldn't bother with anything higher up."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Of course they are better if your ears tell you that, and that's the same for any other wire out there, that's the only way it can be..Are you asking if they're superior to Shotgun's or just in general?ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables
When your gear is at a certain level then there is a real problem telling whats better because components limit the evaluation process. I read a review last night on the eclipse 6 speaker wires and gold eclipse ic's and the reviewer said that he had more expensive cables but he could not tell the difference. He goes onto comment about the components internal wiring is basically going to limit the signal transmited
If your gear has good wiring then the cables will only max out what already is there and cannot work a miracle. With the primaluna and perfectwave dac I doubt I would be able to tell the diff between a reference level full wireworld setup vs a full MIT shotgun setup, although I would still be very interested to try it out. Hope MIT comes back to polk with a new demo as I now feel qualified to give it a fair trial -
You will definitely be able to tell the difference between WW and MIT Shotgun cables due to their network boxes."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
