SDA-2's for Seattle-area pickup $100 OBO
On3s&Z3r0s
It's finally time for me to do some house cleaning (long overdue as far as the wife is concerned), so I'm going to part with my first ever pair of Polks. They are SDA 2's... originals, not A or B. Overall they're in pretty decent shape. They are all stock except for the Cinch jacks for the blade/blade IC which were broken and not making good contact when I bought them from the original owner. I replaced those with new jacks and the stock IC now works fine. The awesome 80's Rec Room Oak veneer is in good shape overall with minor breakage at the back edges of the MDF.
You'll notice from the pics that the nail-in plastic feet were broken on one speaker and were replaced. The height difference worked in my room because one speaker ended up on a section of hardwood and another ended up on a slightly higher tile transition, but the buyer would probably want to replace all the plastic feet or spike them. The only other defect is that one of the passives had its foam start to curl away from the rubber, so I reglued it, which seemed to work well. I have a spare SW-120 I bought to replace it but never felt the need, and I'll throw that in as well. I'd like to keep them whole instead of parting them out, so if anyone local is interested at around $100, they're yours if you can pick them up. Just shoot me a PM if interested, thanks!
Post edited by On3s&Z3r0s on
Boy, sure wish i had the room!Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
starkiller wrote: »Boy, sure wish i had the room!
Me too...:sad: -
The H/T system is all Tannoy, my computer room is tiny and the garage is already full with the RT12b's
Dang+2 Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
