New Equipment Table, What Do You Think?
RamZet
I dumped my old table. It was poorly made and I didn't like it. I picked this bad boy up at Ikea. Very solid and I like it a lot. It also has a place to put my vinyls.
( I know im missing a blank plate, I need to put on still. )
( I also moved my GIANT Genelec sub out of my room. )
What do you think?
What do you think?
B&W CM9Classé Sigma
Post edited by RamZet on
Wow, very nice.
Looks sleek and solid. Really compliments the rest of your setup.
Do you have other shelves for the rest of you vinyl? For the most part, records should be stored upright.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Excellent! I like how it blends in with your gear and how the vinyl records add contrast to the set up. Well done.
Also, thanks for the info on Rotel & B&W on my thread. I had forgotten about it and didn't want to bring it back up from down under. I will consider Rotel and Classe in my next upgrade. -
Wow, very nice.
That is all my vinyl. I have only been collecting for a short while now. I have about 30 albums.Excellent! I like how it blends in with your gear and how the vinyl records add contrast to the set up. Well done.
The records do look cool. I didn't know they should be stored upright. Why is that?B&W CM9Classé Sigma -
Really? I had no idea. I keep mine upright because it's easier to take out and put back in. I've heard the same about VHS too back in the day. -
Very clean, looks fantastic. From what I've read stoing them flat like that can cause the albums to warp.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Very clean, looks fantasticHome Theater
Two Channel
I really like the look of that unit. Very clean, and solid.Samsung UN55C6500 55" LED
Onkyo TX-NR3007
Polk Audio RT5000
-RT3000 front
-CS1000 center
-FX1000 dipole
Polk Audio PSW1000 5.1 sub
Polk Audio microPRO 4000 x2 5.2 subs:biggrin: -
I would definitely avoid the storing of recordings on their sides or flat. I always maintain records in a vertical position. I also remove the original manufacturers wrapping from records and replace them with poly sleeves. These wraps will shrink over time, eventually warping the jacket and it's contents. Warped records suck !!!!If you can't hear a difference, don't waste your money. -
looks nice & clean.
Is that the newer Audio-Technica turntable?
Yes, its the AT-LP240-USB
http://www.audio-technica.com/cms/turntables/1dd57155b119cdad/
It sells for like 400-600 new without a cartridge.
its 30 pounds of awesome. I added a shure m97xB&W CM9Classé Sigma -
Wow, very nice.
Didn't mean to sound like a d***. Your collection will grow in time.
Storing upright helps prevent warping and jacket ringwear etc. You'll also want to make sure there is not a vent behind where you store your albums.
Again, your setup looks amazing.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
I'm an Ikea fan too. Nice clean look. LPs need a little love to remain in good condition - away from temp extremes, especially heat (ie; not in the sun, not near a heat vent), store vertical but take the plastic off & keep them clean. They will last forever. That nice TT of yours should treat them gently so you should be enjoying those albums many decades from now. Ikea sells some boxes that fit albums stored vertically just about perfectly. Search the forums & I'm sure you'll find the name.
good set up.. Congratulations. Enjoy.
Nice table with some notable improvements over the AT-LP120. How do you like it so far?
I think its a good device. Its well built. The feet take some of vibration. The weight helps keep the tone arm stable. The tone are it self can be adjusted like crazy. I also like the small light on the front. I also like that the unit stops when you press the "stop" key. I also just started to look into copying my LPs into my desktop with the USB output. Built in pre-amp is boss too.
I have worked with turntables that run well over 3-6K ( VPI ). From what I have seen its all overkill. I think if you have a decent turntable and great cartridge everything else is just for show.B&W CM9Classé Sigma
