Is this correct
boston1450
boston1450 Posts: 7,671
edited April 2013 in Vintage Speakers
WRONG PICTURE. SORRY
NOT 10's
NOT SURE IF I MESSED UP--(below) - FIRST OFF
I CALLED POLK THIS AFTERNOON. TALKED TO TECH. ASKED ABOUT REPLACEMENT WOOFERS FOR MONITOR 7's. he said they are discontinued.... Ive heard some talk here that they still have them..there is no b on the tag on back so it does say Monitor series 7..did i mess up model. Or maybe they are discontinued ?
Also are monitor 4 & 5jr's drivers the same as i have these as spares
Any feedback is great. Thanks
randy
Post edited by boston1450 on
  • Dawgfish
    Dawgfish Posts: 2,554
    edited April 2013
    OK wait my bad, I understand your original post that this is the wrong pic above. It was unclear to me what you were saying at first. Could you please post some pics of the 7s with shots of the fronts without the grills and the tag on the back by the speaker terminals?
    pitdogg2 Posts: 25,685
    edited April 2013
    Have you pulled the drivers to get a number?
    Ask for Helen or Kim at Polk CS they know their stuff.
  • Dawgfish
    edited April 2013
    ^^+1^^ Pull a MW and then you can see exactly what you have.
  • boston1450
    edited April 2013
    Attachment not found.Ok. I will take pictures. And i will pull driver off. Give me a few min. Thanks
    Toolfan66 Posts: 17,333
    edited April 2013
    I'm guessing it's a MW6502
    Nice speakers BTW..
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • teekay0007
    teekay0007 Posts: 2,289
    edited April 2013
    Yeah, they should be MW6502s in the Monitor 7s, but as others have said, you've gotta pull one out and check it to be sure.
    Most of the Monitor 4s and 5jrs also used the 6502s, so you might be in luck for spares.
  • boston1450
    edited April 2013
    Attachment not found.It appears to be MW 6503 made in 1987 from what we can tell----would this be a Monitor 7 or 7b ? Thanks
    Thanks toolfan66 there mint but dont work. Lol little booboo in shipping--probably happened on Maine frost heaves in road. Lol
  • boston1450
    edited April 2013
    Sorry upside down. I zoomed in. 6503
  • teekay0007
    edited April 2013
    Randy, that MW may have been replaced already, with the wrong driver. You might want to pull the one from the other speaker too, just to be sure. All the Monitor 7 schematics show the MW6502 being used: http://www.polkaudio.com/forums/showthread.php?38755-POLK-AUDIO-Speaker-Wiring-Schematics-amp-More-ALL-MODELS-except-SDA
  • boston1450
    edited April 2013
    Ok. I can do that tomorrow. I take it the 6503 may have been change ? Im not sure whats in the 4's i have or the other 5jr's but maybe i could use them----i was hoping to grab some new ones because these 7s are in great condition. Even if i had to replace both. Odd. Well ill do that in morning.....thanks a bunch all. Your all great----randy
  • boston1450
    edited April 2013
    I just looked at the post. All of them have 6502 like you said
    why would there be a 1987 6503 in this box lol. Like you said someone must of changed it....darn half arsed. I hate that..
    edited April 2013
    Yeah it should be a MW6502 and polk should still have what you need you just need to talk to the right people..
    SVS SB16 X2
    edited April 2013
    The 6503 is a popular driver, too bad it's dead.. The originals fetch $30-$40
    SVS SB16 X2
  • boston1450
    edited April 2013
    So i will check other one....if it is a 6503 should i ask about those? Or should i put 2 6502's in them.....one of the speakers is fine. Just one driver is out of adjustment/spent/froze-up.... Are the 6503's a better driver than the 2's---all my other speakers i asume are 2's and they sound fine NOW....ive had a bad spell with shiped monitors--but thats coming to a end
  • teekay0007
    edited April 2013
    boston1450 wrote: »
    Someone probably swapped out the 6502 for a 6503, thinking they all looked the same so they must be the same. They likely did that following a magnet shift on the original 6502. That can happen sometimes, I've heard. :razz:
    edited April 2013
    The correct driver for the speaker is the better driver..
    SVS SB16 X2
  • boston1450
    edited April 2013
    Great. Because i want them to last me awhile. They are a perfect size,not too big-not too small-for a Yamaha cr820 ---- these monitors are built pretty good. Easy to work on too..i hope soon to upgrade tweeters & maybe even xovers..its kinda fun....thanks alot guys. Ill pull n call them back. Im not talking to same person. I sure hope they have the 6502's as ive been told they possible did.......thanks. Randy
  • boston1450
    edited April 2013
    I couldnt wait till morning----youall were 100% correct. The other driver was a 6502---- well ill be..WTF..lol.. well well well---- i also added the chart to my address book for future reference. Good tool to have. Now im putting in 6502's and i think one by one i will be checking all of them over----glad i had help telling me to pull both. Thanks--randy
