Hurricane Nuts?
smglbrth
Hello Polk Collective,
I am in the process of redoing my 7C's and was wondering if any of you used Hurricane nuts for refastening the drivers/tweets/passives. They seem simpler than T-Nuts as I think T-Nuts would be easier to damage the older wood of the Polks. I don't have any of the rings that so many of you use so I'm looking for a better solution than the old wood screws.
I plan on purchasing new foam tape for everything and once I get the crossovers to Trey (and back) don't plan on ever taking them apart again. I mean, these are almost 30 years old now so I don't foresee any problems for the next 30.
My first "partial" rebuild, next will be my 2A's. However, the expense on these will be a lot cashier!
I was under the understanding that the last run was limited and that there were no more. Please correct me if I'm wrong and I'll get some!!Remember, when you're running from something, you're running to something...-me
Sending you a PM...Remember, when you're running from something, you're running to something...-me
Larry, I am getting ready to start doing the mods on SDA 2.3's that I got the day before yesterday, do you have any of the rings that fit these? ThanksHome Theater
Two Channel
