Original RTA12 's?
EricFromMich
From what I've learned off here so far, I be-leave these to be original rta-12's with a peerless tweeter. I think the stands have but cut down. I'm working on getting a parts list together and am having trouble with some cap values. C1 & C3 . Also is C4 for same value as C6 ? I found allot of info on the 12 B&C but not to much on the original. If I'm missing a thread some place please pass it along. Thanks with any help.
Post edited by EricFromMich on
list of schematics to start with.... http://www.polkaudio.com/forums/showthread.php?38755-POLK-AUDIO-Speaker-Wiring-Schematics-amp-More-ALL-MODELS-except-SDAPolk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
EricFromMich wrote: »
your best option is to read the values off the caps and resistors. You may have to des older if the values are hidden. Also there is no need to replace the Mylar bypass caps if you use high quality film caps."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Polk has little info on the rta12's . I've tired to compare them but from the link above but they seem way off. Thanks steve. -
drumminman wrote: »your best option is to read the values off the caps and resistors. You may have to des older if the values are hidden. Also there is no need to replace the Mylar bypass caps if you use high quality film caps.
I figured as much, was trying to avoid taken them apart more then I had to. I just dont know if the value is on some of them. If they have values have drained then my readings would not make it right. -
http://www.polkaudio.com/forums/attachment.php?attachmentid=18709&d=1155781929
I think this might found the winner just had to look at it with a fresh eye. -
I would still verify by unsoldering to make sure Polk did a lot on the fly.
Or PM Geppy1 he did a whole lot of researching on the 12 knows them inside and out. -
Thanks I'll try that. -
