skematic of RTA 12C's???
soundfreak1
soundfreak1 Posts: 3,414
edited April 2013 in Vintage Speakers
Yhought thete was one but cant find it! Checked polk vintage but no "c's", any help would help as to whare to look. Thanks in advance.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
  • EricFromMich
    EricFromMich Posts: 38
    edited April 2013
    from what i know the b and c are the same cross overs. tweeters might be different and the caps might be different but the same values.
  • jon s
    jon s Posts: 905
    edited April 2013
    My RTA12C's had the same crossover as the RTA12B
  • soundfreak1
    edited April 2013
    Thanks i have found the B. Drawings that will help.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • drumminman
    drumminman Posts: 3,396
    edited April 2013
    jon s wrote: »
    Same here. But . . . . . Definitely check the values printed on the crossover components. I would go by these if they differ from the schematics and are factory original.
  • DaveHo
    DaveHo Posts: 3,536
    edited April 2013
    One difference would be the fuse vs polyswitch for tweeter protection.
  • drumminman
    edited April 2013
    DaveHo wrote: »
    True, although my 12C's, which were purchased new by me in august of 1984, have fuses (C's are supposed to have polyswitches). I plan on replacing these with resistors at some point as I use a clean high power amp to drive them, and I've never blown a fuse or a tweeter despite some very high spl's.
    The schmatics are no doubt useful, but you still gotta look and see what Polk used to build the Xovers.
