sda 2b
chungasrevenge
chungasrevenge Posts: 19
edited April 2013 in Vintage Speakers
I won a pair on an online auction, $41.00, issues, bad tweeter, 3 non working midwoofers. thought it would make a good few month project. a week later on craigslist found a single sda2 for $80.00, the guy took $55.00, all drivers work perfectly. polk sent a mid woofer & ic cable. I stained & oiled the maple caps espresso & I've got a kick **** set of loudspeakers for less than $200.00! running a kenwood km-106 power amp & kenwood kc-206 preamp, this set up is LARGE & i'm loving it. :-D
Post edited by chungasrevenge on
  • deronb1
    deronb1 Posts: 5,021
    edited April 2013
    Congrats! I paid about the same for mine. It is when you start modding them where the coinage starts to add up.
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    edited April 2013
    Congrats. 2B's are some of the best IMO.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,186
    edited April 2013
    Congrats. For a few bucks more you can "TL" them (upgrade the crossover to accept the RD-0198 tweeter). I did that to mine and they sound better than my upgraded SDA 1C's. YMMV
    SDA SRS 2.3TL's
    SDA 2B TL's
    F1nut Posts: 50,753
    edited April 2013
    SDA's never came with maple caps. Oak or walnut was it.
  • pglbook
    pglbook Posts: 2,228
    edited April 2013
    Congratulations. I have a pair of SDA 2B TL speakers myself and love them. They are amazing!
  • teekay0007
    teekay0007 Posts: 2,289
    edited April 2013
    Pic's or it didn't happen! :razz:
  • PolkieMan
    PolkieMan Posts: 2,446
    edited April 2013
    Congrats!
    But I thought the SDA 2B were PIN/BLADE sockets for the interconnect cable? Polk has not carried that cable for quite a while. Your MW drivers should be 6511 and 6503 you said 2B, anyway yes your top/bottom wood caps should be walnut or oak
  • billysam1
    billysam1 Posts: 9
    edited April 2013
    Good score I never win anything ,congrat,s on your win, I have a pair of SDA 2b,s myself and love them . and yes the ic cable is a pin/blade configuration .
    F1nut Posts: 50,753
    edited April 2013
    Early 2B's came with the blade/blade cable.
  • chungasrevenge
    edited April 2013
    that's what I have, i'm enjoying them as the are, a bit strident on the top end, but my graphic equalizer has helped immensely.
    F1nut Posts: 50,753
    edited April 2013
    The SL2000 tweeter is pretty bad. Do the TL upgrade to use the RD0198-1 tweeter for a vastly improved speaker.
    Get rid of the EQ, they have no place in home audio.
  • vmaxer
    vmaxer Posts: 5,117
    edited April 2013
    As usual, great advise. You will love it!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • PolkieMan
    edited April 2013
    Good speakers don't need TONE controls :razz:
    Why don't you tell us what auction site is so we can get some great deals:razz:
  • PolkieMan
    edited April 2013
    F1, So just the socket is from a carryover the actual crossover show be the newer type that will easily be changed to the
    much better Gimpod boards?
    F1nut Posts: 50,753
    edited April 2013
    Yes. The only difference is that the large blade socket doesn't have a connection to the negative binding post. You could add the connection and use the Dreadnaught, if you wanted to use a non-common ground amp(s).
  • PolkieMan
    edited April 2013
    I'm glad they did but I never could understand why they went to a pin/blade when only the pin is active. It seems like just a third properly marked binding post would have been easier and for them cheaper. I guess the fear of a salesman hooking then up wrong was given some thought.
