Replacement stylus for Audio-Technica AT14Sa
jimbo1421
jimbo1421 Posts: 772
edited July 2013 in 2 Channel Audio
Hello,
It is time to replace the Shibata stylus on my Audio-Technica AT14Sa. Its runtime must be near 1000 hours. I have found three replacements online; none of them seem to be original or new old stock. I wonder what you all think of them.
TurntableNeedles.com has one that is for a matching Akai stylus and claims:
Meets the same top of the line shibata specs as the Audio Technica ATN14.
Does this sound right? http://www.turntableneedles.com/AT14-Audio-Technica-ATN14-AKAI-RS-180-Needle-202-DQX_p_924.html
JICO has one here: http://stylus.export-japan.com/product_info.php?products_id=105
No AT logo or much description. Do they make these themselves? JICO seems to be well regarded maker of styli.
The cheapest at $89.95 is from LP Gear. However the description doesn't mention Shibata. It says,
The LP Gear replacement for the Audio-Technica ATN-14 ATN14 needle stylus features a super polished ViVid Line diamond mounted on a thin-wall aluminum alloy cantilever for superior tracing accuracy and fidelity.
What's a ViVid Line diamond? http://www.lpgear.com/product/ATN14.html
Can anyone here offer any insights into these replacements? I am OK with the higher prices if it makes a difference. Are there other suppliers I should look at?
Thanks,
Jim
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro
Post edited by jimbo1421 on
  • Fongolio
    Fongolio Posts: 3,516
    edited April 2013
    I purchased a Jico replacement shibata for my AT20sla and I was happy with it's sound. Needed some time to break in but when it did it was almost indistinguishable from the original AT. One difference though, the Jico was not a nude diamond. Shibata shape but not nude.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • jimbo1421
    edited April 2013
    Thanks for the heads up about the Jico, Fongolio. I am starting to lean towards the Akai version.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • jimbo1421
    edited July 2013
    Just to finish off this thread, I finally settled on the Akai equivalent (ATN14) stylus. I have had it installed for a week now and it has turned out to be an excellent choice. Very clean sounding, a bit brighter than the ATN14 it replaced. Much less noise also. Perhaps it rides higher or lower in the groove than its predecessors.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
