NewClear NC1000
gce
Stumbled on this and was wondering what your guys opinion is? A lot of power for the price but I'm not familiar with this company and how good their amps are.
http://www.tonepublications.com/review/the-newclear-nc1000/
Anaheim Hills CA,
HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
Post edited by gce on
Doesn't look too bad. Never heard of them. $2600 introductory price, talk about trying to break into the high end market off the bat!
Eh. Looks like a lightly modified B&O 1000ASP module. I would start by picking some unmodified modules and if you like the sound, go for that. The modules really are just barely DIY- all you need to add is a case, powercord and some connectors. Those 1000ASP modules are about $500 each, so the question you should ask is whether their mods and a case are worth $1600. From the raw and modified modules I've heard, there really isn't much difference (in raw vs modded) compared to Icepower vs class A/AB.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i
