What kind of oil do you guys put on those SDA's?
Brusco
Brusco Posts: 47
edited April 2013 in Speakers
These SDA's are looking kind of dry, a few scratches here and there but the wood is marvelous. What kind of oil do you guys put on those SDA's CRS's? Whatever you know about these speakers, please do tell. Walnut veneer?
Post edited by Brusco on
  • halo71
    halo71 Posts: 4,635
    edited April 2013
    Castrol 10w40 :cheesygrin:
    --Gary--
  • Brusco
    Brusco Posts: 47
    edited April 2013
    Thanks for your suggestion Gary. Plain old lemon oil containing nothing else, no silicone or waxes, etc.. Is more what I was thinking. I use on my fretboards to keep them from drying out, so why not on speakers right?
  • hosedagain
    hosedagain Posts: 116
    edited April 2013
    halo71 wrote: »
    Try 15W40, has more zinc than 10W40, beneficial for older wood..use it in my vintage motor, older engines require more zinc, same goes for older vintage wood
  • Brusco
    Brusco Posts: 47
    edited April 2013
    oh, so zinc works better than the blue pill?
  • zane77
    zane77 Posts: 1,696
    edited April 2013
    Lol!
    Two Channel
  • nhhiep
    nhhiep Posts: 877
    edited April 2013
  • hosedagain
    edited April 2013
    Brusco wrote: »
    blue pill?
  • Brusco
    Brusco Posts: 47
    edited April 2013
    No, but seriously, I guess it was a dumb question to begin with.
  • ambiophonics
    ambiophonics Posts: 727
    edited April 2013
    Aren't there specific oils for unfinished wood? I have a vintage teak occasional table that I use special teak oil on every few months to keep it looking nice.
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
    F1nut Posts: 51,818
    edited April 2013
    Danish oil (an oil/varnish blend) or the like will do the trick.
    Lemon oil is an oily mineral spirits product (pretty much the same as the mineral oil at the drug store) with lemon scent added. Basically worthless as it starts to evaporate the minute you put it on.
  • Monster Jam
    Monster Jam Posts: 919
    edited April 2013
    nhhiep wrote: »
    snake oil
    Best answer. :)
    Do you hear that buzzing noise? :confused:
    F1nut Posts: 51,818
    edited April 2013
    There's nothing special about it but the price. It will be either tung oil, polymerized tung oil or an oil/varnish mix. Is it glossy, dull or satin after you apply it?
  • ambiophonics
    edited April 2013
    The one I use leaves the wood slightly glossy. It's made by watco, they call is "teak oil" and describe it as a penetrating oil that hardens in the wood, not on the wood. Recommended for teak, mahogany, and rosewood. I know a lot of people use it to restore unfinished teak patio furniture.
    F1nut Posts: 51,818
    edited April 2013
    That's an oil/varnish blend and like I said, there's nothing special about it. The same is sold with a different name by many different brands.
  • ambiophonics
    edited April 2013
    Makes sense, the price wasn't terribly special either, just the fact that it described the exact use I had in mine. It does smell quite nice though!
  • Brusco
    Brusco Posts: 47
    edited April 2013
    I didn't realize when I posted this that there is a Vintage Speakers forum. I should've posted it there. Anyway, these speakers are very dull and dry looking at the moment. I think the wood could use some oil. I find treating wood always turns into a big debate because there's an overwhelming amount of wood finishing products on the market.
  • nspindel
    nspindel Posts: 5,343
    edited April 2013
    That could just mean it's thinned down. I know when I did the maple veneer job on my SDA's and finished with tung oil, the first coat is meant to be thinned down 1:1, so that it penetrates the wood. I did 5 coats total, the first was thinned, the rest were not.
  • DaveHo
    DaveHo Posts: 3,583
    edited April 2013
    Give Howard's Restore-A-Finish a try.
  • Mystery
    Mystery Posts: 2,546
    edited April 2013
    My CRS+'s have laminate veneer so not sure if any oil helps. :confused:
    For wood veneer, tung, howards, lemon whatever works.
  • nspindel
    edited April 2013
    Mystery wrote: »
    My CRS+'s have laminate veneer...
    Good mods are waiting for you!
    F1nut Posts: 51,818
    edited April 2013
    Well no, not whatever works. There are specfic products for specfic jobs. As noted above, lemon oil (mineral oil) is absolutely worthless. Howard's is a shellac based product that is meant to be used over an exsiting clear coat (not an oil finish) finish that has seen better days. It's a band-aid at best. If a clear coat finish has seen better days, get it refinished.
    There's pure tung oil and then there's polymerized tung oil, very different products and both are different than the oil/varnish blend he used.
  • nspindel
    edited April 2013
    I used pure tung oil.
    F1nut Posts: 51,818
    edited April 2013
    Which is perfectly fine as long as one does try to build up the finish too much as it remains relatively soft in it's cured state.
  • nspindel
    edited April 2013
    Right. I love the look of it. It barely looks like there is a finish at all, but it gave a very slight amber hue to the maple.
  • Brusco
    Brusco Posts: 47
    edited April 2013
    I'm going for the no finish look. I want to keep the dry look but deepen the grain. Also these probably have never been treated so I think they're long overdue. I just want to go for the Pledge look without using Pledge.
    F1nut Posts: 51,818
    edited April 2013
    My last post should have read...
    Which is perfectly fine as long as one does NOT try to build up the finish too much as it remains relatively soft in it's cured state.
