Sansui g-5000 receiver==== MAINE
boston1450
boston1450 Posts: 7,676
edited April 2013 in For Sale (FS) Classifieds
Sansui G-5000 it is in very good condition..everything works fine. I used it on tt-tape-tuner. All light-functions work perfect----condition....2 pencil tip dots on top front hard to see..box top has very little mars on it not very noticable. Am antenna thing on back has been broke and slight repaired by previous owner (i can take up close pics if needed) otherwise is PERFECT..... 150.00 LOCAL PICK UP NEAR LEWISTON BRUNSWICK AUGUSTA-- MAINE i can video it also to email or text
thank you randy
This is my first post here on here. If i did it wrong by all means please excuss meAttachment not found.Attachment not found.Attachment not found.Attachment not found.
Post edited by boston1450 on
  • boston1450
    edited April 2013
    Sorry about sideways pics.
  • boston1450
    edited April 2013
    Attachment not found.This pic should look better
  • boston1450
    edited April 2013
  • schwarcw
    schwarcw Posts: 7,341
    edited April 2013
    That Sansui is a beauty! GLWTS
    Carl
  • boston1450
    edited April 2013
    Thanks. If it doesnt sell i will box it up and pull it out in 10 years..it does a fine job too
    edited April 2013
    Some specs on this unit might prove useful for interested buyers, it's a nice unit!
    http://vintageelectronics.betamaxcollectors.com/sansuistereoreceivermodelg-5000.html
    cnh
    1. General
    System: Transistor Receiver
    Colour: 1=Silver, 2=Black: 1
    Pre Amplifier
    Inputs: Phono MM I+II; Tape; AUX; Monitor; Mic
    Quadro: no
    Inp. Sensitivity High Level: 150 mV
    Inp. Impedance High Level: 47 kΩ
    Frequency Response High Level: 5-50,000 (AUX) HZ
    Signal/Noise High Level: 95 (IHF/AUX) db
    Inp. Sensitivity Phono MM: 2.5 mV
    Inp. Impedance Phono MM: RIAA kΩ
    Signal/Noise Phono MM: 78 db
    Outputs: 2 Rec out
    Harmonic Distortion: 0.03 % at rated output
    Equalizer
    Tone Controls: Bass; Treble
    Frequencies: ±10 dB/50 Hz; ±10 dB/10kHz
    Power Amplifier
    Speaker Outputs: 2 x 2 Speakers; Phones
    Continuous Power 4Ω: 80 + 80 (1 kHz) Watts
    Continuous power 8Ω: 47 + 47 (1 kHz); 45 + 45 (20-20,000 Hz) Watts
    Frequency Response: 0-200,000 HZ
    Tuner
    Display: analog
    Frequency Range FM: 88-108 MHz
    Frequency Range AM: 530-1,605 KHz
    Signal Strength Meter: 1 : 0=NO, 1=YES
    Center Tuning Meter: 1 : 0=NO, 1=YES
    Inp. Sensitivity Mono: 1.1 μV
    Frequency Response: 30-15,000 HZ
    Harmonic Distortion: 0.13 (Mono); 0.18 (Stereo) % at rated output
    Separation: > 50 db
    Signal/Noise Mono: 72 db
    Signal/Noise Stereo: 68 db
    Crosstalk: 50 db
    Pilot Signal Rejection: 40 db
    IF Rejection: > 90 db
    2. Physical
    Dimensions in Inches: 18.27 x 7.13 x 16.06 (w) x (h) x (d)
    Dimensions in mm: 464 x 181 x 408 (w) x (h) x (d)
    Weight in lbs: 30.9 lbs
    Weight in Kg: 14.0 Kg
  • boston1450
    edited April 2013
    Thanks cnh. One just sold on the bay with alot of issues for 200.00 or so n shipping. So i think i have it priced right....i have to thank my wife as these things take up alot of room..i sure do miss my sda's----but room is a issue where our living room here is much smaller than Augusta's house had..
  • boston1450
    edited April 2013
    Item has been SOLD....... :)
