i need recom for interor speakers
goingganzo
goingganzo Posts: 2,793
edited December 2003 in Car Subwoofer Talk
ok i have my sq setup allmost done exept of the dionmat and the interor speakers. i dident think i need the dino mat till i got a great sub. i had 2 kicker xpl 12 running off a alpine mrv 1000 and it was good then i diy a ht sub and bought 3 of them but olny used 2 so i took the 3rd and put it in my car a 2 cube sealed with a av15 frome stryke. this gives me a sub with a q of .06 or.6 i dont rember off hand. now i need interor speakers. i have 6x9 in rear and 4x6 up front with tweets in the sail panel. thanks bugget up to 250 per set of speaker and fronts must have tweets be able to put in sail the pannel
thanks.
ps my sub has 23mm of x max and i got it for 165
Post edited by goingganzo on
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    the best 4x6s ive ever heard(plate or oval) is the kenwood exceleron kfc x468c, theyre in crutchfield for $100
    go to sounddomain, then Image Dynamics and look at their tweeters
    and momo or DB 6x9s should suite you find in the back
    -Cody
