Benefits of 7.1 HT
Irrenhaus
Irrenhaus Posts: 1,105
edited April 2013 in Speakers
Hi all
Currently my HT setup is 5.1 and I am happy. Its there a benefit by adding the two back surrounds the only problem I see is that my couch is against the back wall and my surrounds are on the sides walls aim in an angle towards the couch and a bit to the center of the room. If I add the two back they will be place above the couch on the sides pointing downward to the center of the room.
I can get this one:
RTi4 for $119.00 a pair
RTi6 for $179.00 a pair
On sale at Frys also many other ones on sale.
RTi8
RTi12 and centers
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • kuntasensei
    kuntasensei Posts: 3,263
    edited April 2013
    Most people are going to say that you should stick with 5.1. You're going to hear, "A well-placed 5.1 system is better than a poorly placed 7.1 system" ad nauseum.
    However, most big-name Hollywood flicks are now done in 7.1 theatrically, so sticking to 5.1 doesn't get you an accurate representation of the theatrical mix in those cases. I'm in a similar boat to you, in that my couch was against the back wall. However, I pulled the couch a foot away from the wall and put surround backs up on B-tech mounts so that they're aimed down to my listening area. With a little careful tweaking of distance settings, I get a very solid rear soundstage, which proponents of 5.1 will tell you shouldn't be the case. Another less popular option would be placing the speakers on the floor behind the couch, aiming straight up. It may not look great, but it actually sounds pretty decent.
    So is there a benefit? YES. The benefit is that you can't play a movie mixed for 7.1 on a 5.1 system and get the same sound you would have in the theater. Whether you can make it work in your room is the question... and I say roll the dice. Worked for me! (And worst case scenario, you get stuck with the speakers and try them as height channels or width channels instead.)
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • Mystery
    Mystery Posts: 2,546
    edited April 2013
    7.1 is only better in these situations.
    1. If you have a room to have a good distance from side to rear surrounds.
    2. If the source has discrete 7.1 channels like new movies off of blu-ray disc otherwise receiver simulates 5.1 to 7.1 which may or may not be as good.
    3. If you have weird room setup and like more presence in the back.
    Otherwise, 5.1 would be enough.
    I have a small room but use 7.1 because my side surrounds are setup little odd due to weird fireplace location.
  • teekay0007
    teekay0007 Posts: 2,288
    edited April 2013
    Like he said. +1
  • Mystery
    edited April 2013
    teekay0007 wrote: »
    Like he said. +1
    That's true and everyone says that but not a good comparison.
    A good comparison would be "A well-placed 7.1 vs a well placed 5.1" and I'm pretty confident 7.1 will be better as long as source has 7.1 channels.
    Nowadays, people even use front fill or presence speakers in addition to 7.1. :eek:
  • kuntasensei
    edited April 2013
    Mystery wrote: »
    Don't be scared... I'm running a 9.2 setup and height channels are AWESOME. :cheesygrin:
    Equipment list:
    Emotiva XPA-3 amp
  • pearsall001
    pearsall001 Posts: 5,390
    edited April 2013
    You guys are all rookies... :razz: move on up to an 11.2 system & be prepared to be dazzled. :lol: Now of course this is strictly room dependant but if you have the space go for it. Wait till Dolby releases their new "Atmos" system, I believe it'll be over 60 speakers in the theater. Dang!!! My front & presence speakers really add another whole dimension to movie soundtracks.
  • RamZet
    RamZet Posts: 792
    edited April 2013
    If you have the room and if you watch most of your movies on bluray I would say go for it. If youre like me and rent all your movies from Apple TV (unless its a blockbuster like sherlock, BatMan or iron man) I would stick to 5.1
    B&W CM9Classé Sigma
  • rpf65
    rpf65 Posts: 2,127
    edited April 2013
    Good price on the speakers. I could be wrong,but it sounds that if you want to go from 5.1 to 7.1, you may want to look into di-pole/bi-pole speakers. Sure, you could probably make front firing speakers work, with some degree of success, but I would probably go the other direction. Just something to think about.
  • rromeo923
    rromeo923 Posts: 1,513
    edited April 2013
    I had a nice 7.1 system. Sold it all. Now rocking 2.0 and havent looked back.
    I got static in my head
  • Geoff4rfc
    Geoff4rfc Posts: 3,043
    edited April 2013
    I've used a 7.1 from the beginning trying rears, heights and wides. My AVR does a tremendous job at matrixing the wide channel. Plus, I use an extra set of towers in the wide spot and my front stage is doubled in sound at all the right moments.
  • Irrenhaus
    edited April 2013
    Hey thanks to all for the comments and recommendations. I think for now I will stick with 5.1 is doing fine and it seems that I will be moving to a new place in the summer so I will wait till then. But I may still grab those RTi4 for 119.00 this week is a good deal..:smile:
