Denon 4810
I took my Denon 4810 for repair I was unable to use the Usb . I connected everything but I can not get the Subwoofer to work . Please post any ideas . Thanks
Post edited by jdenon4810 on
  • rpf65
    rpf65 Posts: 2,127
    edited May 2013
    Did you go into the speaker set-up screen and turn the sub on?
    edited May 2013
    ....and what does the USB have to do with a subwoofer ? What are you using the USB for anyway ?
    You need to set up the receiver and all the inputs. If you have a manual, read it cover to cover....twice. No joke, they can be very confusing
    edited May 2013
    Tonyb is right. And older Denon manuals, in particular are, IMHO, the very worst ever written. I have an AVR 2807 below...the manual pretty much sucked. And the Menu system on these older Denons are counter-intuitive with various functions buried under layer after layer. It's often not that easy to find what you're looking for.
    But you MUST tell the AVR you have a sub and also set the crossover for it. Also be CAREFUL that you have NOT hooked the SUB cable to the Sub multi-channel in rather than the SUB PRE-OUT! That is a very common oversight!
    cnh
