Vince
sntnsupermen131
got the tweeter today, it looks like the exact same thing as the momo tweeter cept the mm tweeter is red, the dx is blue
but you cant tell when youre sitting in the cab b/c the dash covers the driver's side tweeter
but it fits perfect, i just need to get a hold of a hot glue gun when i get home and it has a 90% chance of getting done today
should i just duct tape the wire to the panel so it wont come off?
Thanks again!
-Cody
Thanks again!
-Cody
Post edited by sntnsupermen131 on
no problem dude -- far as duct taping, i don't know... i mean are u talking inside the panel ? or outside? -- i wouldn't put tape on a visible panel - that'd be mega ghetto... if u mean inside, then why not just hot glue the wire to the door inside, that might be more solid than taping it. either way, it should work out ok i think.
hope it sounds kosher.The Artist formerly known as PoweredByDodge -
yes, definetely inside, but i might hot glue it, probably be safer that way
-Cody -
ahhhhhhhhhhh
its in
finally
i kind of forgot how f***ed up my sound stage really was
and in comparison of the dx and momo, the momo sounds a LITTLE bit better IMO
but definetely has better power handling...
but the DX isnt that far behind
very nice tweeter
thanks again, im so glad, you have no idea
lol
-Cody -
glad to see it worked out
bling bling loud music rawksThe Artist formerly known as PoweredByDodge
